Unable to connect with Loki. Please check the server logs for more det
Hi everyone,
I’m currently trying to set up the Loki plugin via Grafana but I always get the error message “Unable to connect with Loki. Please check the server logs for more details” when I want to add the data source in Grafana. I have Grafana and Loki installed on an Unbuntu server. I followed these instructions. Local | Grafana Loki documentation
The ports are of course all unlocked
[Unit]
Description=Loki service
After=network.target
[Service]
Type=simple
User=loki
ExecStart=/usr/local/bin/loki -config.file /etc/loki/loki-local-config.yaml
Restart=on-failure
RestartSec=20
StandardOutput=append:/etc/loki/logs/loki.log
StandardError=append:/etc/loki/logs/loki.log
[Install]
WantedBy=multi-user.target
auth_enabled: false
server:
http_listen_port: 3100
grpc_listen_port: 9096
log_level: debug
grpc_server_max_concurrent_streams: 1000
common:
instance_addr: 127.0.0.1
path_prefix: /tmp/loki
storage:
filesystem:
chunks_directory: /tmp/loki/chunks
rules_directory: /tmp/loki/rules
replication_factor: 1
ring:
kvstore:
store: inmemory
ingester_rf1:
enabled: false
query_range:
results_cache:
cache:
embedded_cache:
enabled: true
max_size_mb: 100
schema_config:
configs:
store: tsdb
object_store: filesystem
schema: v13
index:
prefix: index_
period: 24h
pattern_ingester:
enabled: true
metric_aggregation:
enabled: true
loki_address: localhost:3100
ruler:
alertmanager_url: http://localhost:9093
frontend:
encoding: protobuf
hi there,
Is there any output/logs from Loki server? Does Grafana run on the same server as Loki? Is port 3100 open in your firewall?
