v11.2.0 (2a88694fd3)
Distributor ID: Ubuntu
Description: Ubuntu 22.04.4 LTS
Release: 22.04
Codename: jammy
- What are you trying to achieve?
Trying to connect Grafana to loki on the Data sources page for Loki - How are you trying to achieve it?
By enteringhttp://loki:3100,http://10.0.0.70:3100orhttp://localhost:3100in the Connection tab (URL) - What happened?
Unable to connect with Loki. Please check the server logs for more details.
If I go to the pagehttp://loki:3100on a web browser I get a 404 error. - What did you expect to happen?
For it to connect successfully - Can you copy/paste the configuration(s) that you are having problems with?
docker-compose.yml
version: "3"
networks:
loki:
services:
loki:
image: grafana/loki:2.4.0
volumes:
# Maps your host's loki configuration file to the expected path inside the container
- /home/loki/loki1/loki-config.yml:/etc/loki/loki-config.yml
ports:
- "3100:3100"
restart: unless-stopped
command: -config.file=/etc/loki/loki-config.yml
networks:
- loki
promtail:
image: grafana/promtail:2.4.0
volumes:
- /var/log:/var/log
# Maps your host's promtail configuration file to the expected path inside the container
- /home/loki/promtail/promtail-config.yml:/etc/promtail/promtail-config.yml
command: -config.file=/etc/promtail/promtail-config.yml
networks:
- loki
grafana:
image: grafana/grafana:latest
volumes:
- /home/serveradmin/docker_volumes/grafana:/var/lib/grafana
ports:
- "3000:3000"
networks:
- loki
user: root:root
loki-config.yml
auth_enabled: false
server:
http_listen_port: 3100
grpc_listen_port: 9096
common:
path_prefix: /tmp/loki
storage:
filesystem:
chunks_directory: /tmp/loki/chunks
rules_directory: /tmp/loki/rules
replication_factor: 1
ring:
instance_addr: 127.0.0.1
kvstore:
store: inmemory
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
ruler:
alertmanager_url: http://localhost:9093
I may as well include promtail
promtail-config.yml
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /tmp/positions.yaml
clients:
- url: http://loki:3100/loki/api/v1/push
scrape_configs:
# local machine logs
- job_name: local
static_configs:
- targets:
- localhost
labels:
job: varlogs
__path__: /var/log/*log
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
docker logs loki_grafana_1 output:
logger=tsdb.loki endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=checkHealth pluginId=loki dsName=loki dsUID=cdxmlpmgt0pvkb uname=admin fromAlert=false t=2024-09-12T01:56:46.49556451Z level=error msg="Error received from Loki" duration=2.432519ms stage=databaseRequest statusCode=400 contentLength=65 start=1970-01-01T00:00:01Z end=1970-01-01T00:00:04Z step=1s query=vector(1)+vector(1) queryType=instant direction=backward maxLines=0 supportingQueryType=none lokiHost=loki:3100 lokiPath=/loki/api/v1/query status=error error="parse error at line 1, col 1: syntax error: unexpected IDENTIFIER" statusSource=downstream
logger=tsdb.loki endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth endpoint=CheckHealth t=2024-09-12T01:56:46.495757751Z level=error msg="Loki health check failed" error="error from loki: parse error at line 1, col 1: syntax error: unexpected IDENTIFIER"
logger=context userId=1 orgId=1 uname=admin t=2024-09-12T01:56:46.495872518Z level=info msg="Request Completed" method=GET path=/api/datasources/uid/cdxmlpmgt0pvkb/health status=400 remote_addr=10.0.0.10 time_ms=6 duration=6.407487ms size=106 referer=http://10.0.0.70:3000/connections/datasources/edit/cdxmlpmgt0pvkb handler=/api/datasources/uid/:uid/health status_source=server
- Did you follow any online instructions? If so, what is the URL?
I mostly followed this guy’s guide.
Meet Grafana LOKI, a Log Aggregation System for Everything | Techno Tim
