I have installed loki and grafana in the monitoring namespace using helm charts. I’ve included the values.yaml I used for them.
I am trying to add the Loki datasource using the Grafana UI, however I keep getting an error.
Loki values.yaml
deploymentMode: SingleBinary
loki:
commonConfig:
replication_factor: 2
schemaConfig:
configs:
store: tsdb
index:
prefix: loki_index_
period: 24h
object_store: s3
schema: v13
storage:
type: 's3'
bucketNames:
chunks: loki-chunks
ruler: loki-ruler
admin: loki-admin
s3:
endpoint: <endpoint>
region: <region>
accessKeyId: <access-key>
secretAccessKey: <secret>
s3ForcePathStyle: false
insecure: false
test:
enabled: false
singleBinary:
replicas: 2
persistence:
storageClass: alicloud-disk-essd
lokiCanary:
enabled: false
gateway:
ingress:
enabled: true
ingressClassName: nginx
annotations:
cert-manager.io/cluster-issuer: letsencrypt-prod
nginx.ingress.kubernetes.io/force-ssl-redirect: "true"
labels: {}
hosts:
- host: loki.example.com
paths:
- path: /
pathType: Prefix
tls:
- secretName: loki-gateway-tls
hosts:
- loki.example.com
basicAuth:
enabled: true
existingSecret: loki-gateway-ingress-basic-auth
read:
replicas: 0
backend:
replicas: 0
write:
replicas: 0
Grafana values.yaml
replicas: 2
ingress:
enabled: true
annotations:
path: /
pathType: Prefix
hosts:
- grafana.example.com
tls:
- secretName: grafana-tls
hosts:
persistence:
type: pvc
enabled: true
storageClassName: alicloud-disk-essd
accessModes:
- ReadWriteOnce
admin:
existingSecret: grafana-admin-creds
userKey: admin-user
passwordKey: admin-password
Grafan UI
Loki Gateway logs
192.168.0.62 - lokiuser [07/Oct/2024:07:43:57 +0000] 401 "GET /loki/api/v1/query?direction=backward&query=vector%281%29%2Bvector%281%29&time=4000000000 HTTP/1.1" 10 "-" "Grafana/11.2.1" "-"
If I try to fetch /loki/api/v1/status/buildinfo from my laptop or the grafana Pod I get a 200 response but 401 response if I try to add the loki datasource from the UI
Grafana Pod shell
grafana-7cd7f5c57d-fvwgr:/usr/share/grafana$ curl -u lokiuser:lokipasswd http://loki-gateway/loki/api/v1/status/buildinfo
{"version":"release-3.1.x-89fe788","revision":"89fe788d","branch":"release-3.1.x","buildUser":"root@buildkitsandbox","buildDate":"2024-08-08T14:25:46Z","goVersion":""}
Port Forwarding Loki gateway to localhost 3100
curl -u lokiuser:lokipasswd http://localhost:3100/loki/api/v1/status/buildinfo
Did I miss some configuration?
