Hi all, I’m new to Grafana and found out that there’s a log aggregation using Loki with the help of Promtail. I was able to install and fetched logs from my localhost. I would want to get logs from remote servers (i.e: nginx logs from a remote nginx web server) and push it to my grafana server. What could be the possible way of doing it? Thanks so much!
From my server:
my-promtail-config.yaml
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /data/loki/positions.yaml
clients:
Remote server (not sure if i have to add promtail and push to my grafana server):
server:
grpc_listen_port: 0
positions:
clients:
@sanlupam03 hi, thanks for your question.
You’ll need to install promtail on every host that you intend to fetch logs from. These promtail instances should all be configured to push to the same central Loki installation.
Thanks, I have already promtail installed to my remote server
Remote server’s promtail config:
grpc_listen_port: 0
positions:
clients:
- url: http://loki-server-domain-name:3100/loki/api/v1/push
scrape_configs:
- job_name: nginx
static_configs:
- targets:
- localhost
labels:
job: nginx
__path__ : /var/log/nginx/*.log
host: remote-logs
Remote server promtail service message:
promtail-linux-amd64[29850]: level=error ts=2022-02-11T08:45:59.23847224Z caller=client.go:360 component=client host=loki-server-domain-name:3100 msg=“final error sending batch”
Thanks
That’s not enough for me to go on, I’m afraid.
Are you sure your promtail server can communicate with your Loki server on that port?
Hi, on localhost, promtail server can talk to loki server
Loki server config:
server:
http_listen_port: 3100
grpc_listen_port: 9096
common:
path_prefix: /tmp/loki
storage:
filesystem:
chunks_directory: /tmp/loki/chunks
rules_directory: /tmp/loki/rules
replication_factor: 1
ring:
instance_addr: 127.0.0.1
kvstore:
store: inmemory
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
ruler:
alertmanager_url: http://localhost:9093
promtail localhost config:
server:
grpc_listen_port: 0
positions:
clients:
- url: http://localhost:3100/loki/api/v1/push
scrape_configs:
- job_name: nginx
static_configs:
- targets:
- remote-server-ip
labels:
job: nginx
__path__: /var/log/nginx/*.log
host: grafana
But the problem is with your remote promtail, right?
Hi, ah, yes the problem was on the side of remote promtail / remote server connecting to our local loki.
Output of curl from our remote host/server.
* Trying loki.server.ip.address...
* TCP_NODELAY set
* Connected to loki-server.domain (loki.server.ip.address) port 3100 (#0)
> GET /loki/api/v1/push HTTP/1.1
> Host: loki-server.domain:3100
> User-Agent: curl/7.58.0
> Accept: */*
< HTTP/1.1 405 Method Not Allowed
< Date: Fri, 11 Feb 2022 12:07:50 GMT
< Content-Length: 0
* Connection #0 to host loki-server.domain left intact
Hi, I think I found the error of my remote promtail but currently observing it.
I didn’t notice that config on client was set to:
client:
url: http://loki-server.domain:3100/loki/api/v1/push
then I changed to:
clients:
- url: http://loki-server.domain:3100/loki/api/v1/push
