Loki log synchronization lost
Prommail captured all logs, but when pushed to Loki, Loki did not synchronize all logs
  • grafana version:9.4.7 Ubuntu 23.04
  • data sources : Loki
  • Query the keywords common to each log file by explore
  • Purpose: Obtain device status changes through monitoring diary files
  • Realization: promtail grabs the logs and pushes them to loki
  • problem:promtail crawled all the logs, but after pushing found that the number of loki logs is not correct, lost a lot of logs
  • Configuration files:
    loki :2.8.0
auth_enabled: false
server:
  http_listen_port: 3100
  grpc_listen_port: 9096
  # log_level: debug
limits_config:
  reject_old_samples: true
  reject_old_samples_max_age: 24h
  retention_period: 24h
    # max_query_series: 10000
  max_query_parallelism: 2 # Maximum number of queries that will be scheduled in parallel by the frontend.
  max_query_lookback: 24h
  query_timeout: 5m
  enforce_metric_name: false
  ingestion_rate_mb: 40
  ingestion_burst_size_mb: 20
  #max_global_streams_per_user: 0
# frontend:
#   max_outstanding_per_tenant: 1024
# query_scheduler:
#   max_outstanding_requests_per_tenant: 50
common:
  instance_addr: 127.0.0.1
  path_prefix: /tmp/loki
  storage:
    filesystem:
      chunks_directory: /tmp/loki/chunks
      rules_directory: /tmp/loki/rules
  replication_factor: 1
  ring:
    kvstore:
      store: inmemory
query_range:
  results_cache:
    cache:
      embedded_cache:
        enabled: true
        max_size_mb: 10000
schema_config:
  configs:
      store: boltdb-shipper
      object_store: filesystem
      schema: v11
      index:
        prefix: index_
        period: 24h
table_manager:
  retention_deletes_enabled: true
compactor:
  working_directory: /tmp/loki/retention
  shared_store: filesystem
  # compaction_interval: 10m
  retention_enabled: true
  # retention_delete_delay: 10s
  retention_delete_worker_count: 150
  #todo
  compaction_interval: 24h
  retention_delete_delay: 48h
ruler:
  storage:
    type: local
    local:
      directory: /loki/rules
  rule_path: /loki/rules-temp
  alertmanager_url: http://192.168.152.160:9093
  ring:
    kvstore:
      store: inmemory
  enable_api: true
  enable_alertmanager_v2: true
promtail:2.43.0
server:
  http_listen_port: 9080
  grpc_listen_port: 0
  log_level: debug
positions:
  filename: /tmp/positions.yaml
clients:
  - url: http://localhost:3100/loki/api/v1/push
    # batchsize: 102400
    timeout: 30s
limits_config:
   readline_rate_enabled: true
   max_streams: 1000
   readline_rate_drop: false
  # max_line_size: 2M
  #readline_burst: 1000
scrape_configs:
- job_name: deviceLog
  static_configs:
  - targets:
      - localhost
    labels:
      job: localserver
      __path__: /home/tjc/log/localserver/002*/*.log
  - targets:
      - localhost
    labels:
      job: bob
      __path__: /home/tjc/log/bob/002*/*.log
  - targets:
      - localhost
    labels:
      job: media
      __path__: /home/tjc/log/media/002*/*.log
promtail log
level=info ts=2023-06-08T08:24:08.553160574Z caller=filetargetmanager.go:178 msg="received file watcher event" name=/home/tjc/log/bob/002271/997rx.log op=CREATE
level=debug ts=2023-06-08T08:24:08.553215833Z caller=filetargetmanager.go:432 msg="new file does not match glob" filename=/home/tjc/log/bob/002271/997rx.log
level=debug ts=2023-06-08T08:24:08.553232104Z caller=filetargetmanager.go:432 msg="new file does not match glob" filename=/home/tjc/log/bob/002271/997rx.log
level=debug ts=2023-06-08T08:24:08.553264148Z caller=filetarget.go:330 msg="tailing new file" filename=/home/tjc/log/bob/002271/997rx.log
ts=2023-06-08T08:24:08.553401481Z caller=log.go:168 level=info msg="Seeked /home/tjc/log/bob/002271/997rx.log - &{Offset:0 Whence:0}"
level=info ts=2023-06-08T08:24:08.553434201Z caller=tailer.go:143 component=tailer msg="tail routine: started" path=/home/tjc/log/bob/002271/997rx.log
  • No error message in the log
  • Configure according to the official documentation
