I am using Grafana 8.0.0 -
I am trying to set-up Grafana Operator High availability with 3 replicas of Grafana in AKS with postgres db as it’s backend and set-up cache for it’s sessions -
What happened?
I am trying to connect memcache with Grafana, while trying that i can’t see any key stored in memcache by grafana for it’s sessions -
remote_cache:
type: memcached
connstr: 10.78.236.77:11211
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
None - Did you follow any online instructions? If so, what is the URL?
