Grafana Redis Configuration
    Grafana Version 8.1.2
    Debian 10 Buster
    Grafana Caching into redis
  • What happened?
    grafana is not using the redis cache
    that it use the cache
[remote_cache]
Either “redis”, “memcached” or “database” default is “database”
type = redis
connstr = addr=127.0.0.1:6379,db=0,ssl=false
No errors at all in the logs
Which back-end data store/s do you use, and how many queries do you have in
your dashboard/s?
Antony.
@markohorn maybe this helps: remote_cache 6.1.x redis configuration · Issue #16488 · grafana/grafana · GitHub. In a nutshell; the cache is probably not being used
