- What are you trying to achieve?
I created an XY Chart of outside temperature (as X) and humidity (as Y), and I want to have the linear regression : humidity = f(temperature) and display its equation and R² in the tooltip of the line (or as legend of the graph or as permanent label on the graph)
- How are you trying to achieve it?
I already managed to display the linear regression on the XY Panel thanks to the Regression Transformation :
But now I want to display the equation and the R². Does someone know how to do it please ?
What happened?
Line properly displayed but no possibility to get its equation or R² -
Automatic configuration of a tooltip containing the equation and R² (a bit like Excel display)
Or : manual toggle to say that I want to display the equation and R²
Grafana v11.3.1 (64b556c137)
Thanks in advance for your help !
