How to use regressionTransformation, cannot see its option in Transforms after enabling
I am running Grafana version 10.1.5-ubuntu docker image
I want to generate an alert on timeseries based on linear regression slope.
I have enabled the regressionTransformation by passing the environment variable
GF_FEATURE_TOGGLES_ENABLE=regressionTransformation,transformationsVariableSupport
In the docker compose file.
  • What happened?
If I go to grafana admin page and see Settings I can see this is enabled.
feature_toggles
enable regressionTransformation,transformationsVariableSupport
But when I go to timeseries panel, transform option. I cannot see regreesion.
See the option to use regression somewhere?
Can someone from Grafana team answer this please?
I would appreciate it as well :slight_smile:
I resolved for myself. I am using grafana in docker.
Set up these env variables:
  • GF_FEATURE_TOGGLES_ENABLE=featureToggleAdminPage, regressionTransformation
  • GF_FEATURE_MANAGEMENT_ALLOW_EDITING=true
After that restarted the grafana.
