RefID in Math Expression with hyphens ( - ) causes internal server error
    Grafana version: v11.0.0
    Operating system: Windows 11 Business (version 23H2)
    Referencing a RefID in an Expression with Operation math that has a hyphen ( - ) in it, such as $my-ref-id.
    In the Grafana UI when querying for a panel.
  • What happened?
    Received an icon with the text Query error: 500 Internal Server Error in the upper left corner of the panel.
    To reference the data of the RefID.
    $my-ref-id, I also tried ${my-ref-id}.
status:500
statusText:"Internal Server Error"
data:Object
message:"Query data error"
traceID:""
config:Object
traceId:undefined
message:"Query error: 500 Internal Server Error"
Just don’t use hyphens in ref id. They are interpreted as minus usually, so you will have problem in many programming languages with this syntax.
Hi @jangaraj,
Thanks for the answer.
Yes that was our conclusion as well, where we migrated from using hyphens. I was just interested if there was another workaround (such as using brace syntax) and that it maybe could be of interest to highlight this in the documentation (as the received internal server error wasn’t too precise).
