Please help us how to connect to redshift from grafana by Postgres datasource.
Host : postgres://un:pw@sever.redshift.amazonaws.com:5439
Database :
User :
Password: <combination of alphabets and letters;no special characters>
SSL Mode : Verify-ca
Error :
t=2017-12-20T14:46:45+0000 lvl=eror msg=“Request Completed” logger=context userId=3 orgId=1 uname=*****@.com method=POST path=/api/tsdb/query status=500 remote_addr=127.0.0.1 time_ms=52 size=217 referer=https://******.in/datasources/edit/23
@anon34853223 @torkel
Could anyone please help on it
Please try and remove the postgres:// from the host field.
Marcus
After removing postgres:// from the host field.
It should work with redshift (see here for an example: AWS Redshift using Postgres fails to connect)
What do you have in the host field? You should only need sever.redshift.amazonaws.com:5439 and then the user field should contain the username and the password field should contain the password.
Grafana builds the connection string from the fields.
Error:
t=2017-12-20T17:15:26+0000 lvl=eror msg=“Request Completed” logger=context userId=3 orgId=1 uname=************** method=POST path=/api/tsdb/query status=500 remote_addr=127.0.0.1 time_ms=29 size=257 referer=https://******.in/datasources/edit/23
sever.redshift… is just an example host url. What is your actual host url for your redshift cluster?
http://docs.aws.amazon.com/redshift/latest/mgmt/connecting-from-psql.html
Thanks Daniellee im able to connect now
