Grafana v8.2.0 (d7f71e9eae)
- What are you trying to achieve?
Use Redshift as PostgreSQL data source.
- How are you trying to achieve it?
I have set my host:port, database, user and password. My password contains the following special characters . and !. TLS/SSL is disabled.
- What happened?
When I click Save and Test I’m happily greeted by the Database Connection OK message, however after using the chrome inspector things look a bit different:
/api/datasources/uidrequest seems ok, even though my password is an empty string, I’m seeing thatsecureJsonFields: {password: true}so I guess that’s fine/api/dserrors out withdb query error: failed to connect to server - please inspect Grafana server log for detailswhen trying theSELECT 1query. This request returns400 Bad Requestbut the UI is fine with it
Note that I am able to connect to my database using the exact same credentials. Also my /var/log/grafana folder is empty for whatever reason. I’m running the Docker contains with the default settings.
I read through the few issues available here and on GitHub and even though they seem a bit outdated at this point the hint at that using Redshift as data source is actually possible. So, I was looking for that.
- Can you copy/paste the configuration(s) that you are having problems with?
It’s really my credentials only, and as I mentioned earlier they work outside of Grafana.
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
on SELECT 1 but the UI tells me that Database Connection OK
- Did you follow any online instructions? If so, what is the URL?
I used this one Run Grafana Docker image | Grafana documentation
