My grafana dashboard was earlier working fine and was showing charts and graphs while being linked to a Postgres DB. I had to add some environment variables and add some plugins. So I updated the grafana docker-compose file and added some extra env variables.
When I rebuild the docker container and ran the docker container, I got some errors. Although I was able to get the required changes in grafana and add the plugins, I had some issues with connecting with data sources.
Now I get the following error in data sources while connecting with postgres SQL.
db query error: pq: password authentication failed for user "postgres"
Earlier it was working fine. Now, how come it is having issues now? Am I doing something wrong? (Also, this change fine locally but not in production)
There’s a lot of “some” in that description, with no detail about what
variables you defined (and why) or which plugins you added.
Again, what were the “errors” and what are the “issues”?
postgres SQL.
db query error: pq: password authentication failed for user “postgres”
So, the first question would be - can you connect manually (ie: using the
postgres command-line client) from the machine running Grafana, and using the
same credentials?
