Hello all
I would like to use Grafana for visualize data from InfluxDB.
I’ve been able to create the connection between InfluxDb.v2 & Grafana
When I try to create a dashboard, there’s no query wizard
like this one :
This last connection isn’t configured.
Which are the step to restore this query wizard with my connected database ?
Gafana v10.2.2 in a docker container on Debian Bulleyes 64b -
I tried to create a new dashboard -
trying to create a query with the wizard -
What happened?
No query Wizard on a fresh Grafana installation in a docker container
no error in log -
