Query options wont let me change the timespan for my panel permanently
Hi everyone
  • I want to permanently change the timespan of a panel so it only shows me the processed data from the past 7 days ?
  • I tried to change the query option with setting the relative time to “now-7d/d”.
  • Afterwards it is showing me the timespan of 7 days correctly but only for the time i wont refresh my dashboard.
  • I wanted that timespan to be there permanently even after i save my dashboard and refresh it.
Is there any way to solve this problem with a code syntax in this case “Athena”, the Query options or some Transformation ?
Greetings and thx in advance :slight_smile:
L
have you tried using the time-picker and setting it to now-7d?
