Hi everyone, I have issue about query from Grafana Loki just show log today, how to configure if I want to query 7 days before ?
I use deployment microservices and S3 Object Storage Internal, running in OCP Development
Here is config file
analytics:
reporting_enabled: false
auth_enabled: false
bloom_build:
builder:
planner_address: loki-bloom-planner-headless.loki.svc.cluster.local:9095
enabled: false
bloom_gateway:
client:
addresses: dnssrvnoa+_grpc._tcp.loki-bloom-gateway-headless.loki.svc.cluster.local
enabled: false
chunk_store_config:
chunk_cache_config:
background:
writeback_buffer: 500000
writeback_goroutines: 1
writeback_size_limit: 500MB
default_validity: 0s
memcached:
batch_size: 4
parallelism: 5
memcached_client:
addresses: dnssrvnoa+_memcached-client._tcp.loki-chunks-cache.loki.svc
consistent_hash: true
max_idle_conns: 72
timeout: 2000ms
common:
compactor_address: 'http://loki-compactor:3100'
path_prefix: /var/loki
replication_factor: 3
storage:
s3:
access_key_id: ${ACCESS_KEY_ID}
bucketnames: ocp-chunks
endpoint: ${ENDPOINT}
http_config:
insecure_skip_verify: true
insecure: true
s3forcepathstyle: true
secret_access_key: ${SECRET_ACCESS_KEY}
compactor:
apply_retention_interval: 1h
compaction_interval: 5m
delete_request_store: s3
retention_delete_worker_count: 500
retention_enabled: true
frontend:
scheduler_address: loki-query-scheduler.loki.svc.cluster.local:9095
tail_proxy_url: http://loki-querier.loki.svc.cluster.local:3100
frontend_worker:
index_gateway:
mode: simple
ingester:
chunk_encoding: snappy
limits_config:
allow_structured_metadata: true
max_cache_freshness_per_query: 10m
max_entries_limit_per_query: 50000
max_query_lookback: 168h
query_timeout: 300s
reject_old_samples: true
retention_period: 168h
split_queries_by_interval: 15m
volume_enabled: true
memberlist:
join_members:
- loki-memberlist
pattern_ingester:
enabled: true
querier:
max_concurrent: 4
query_range:
align_queries_with_step: true
cache_results: true
results_cache:
cache:
background:
default_validity: 12h
memcached_client:
addresses: dnssrvnoa+_memcached-client._tcp.loki-results-cache.loki.svc
timeout: 500ms
update_interval: 1m
ruler:
storage:
s3:
bucketnames: ocp-ruler
http_config:
insecure: true
type: s3
wal:
dir: /var/loki/ruler-wal
runtime_config:
file: /etc/loki/runtime-config/runtime-config.yaml
schema_config:
configs:
index:
period: 24h
prefix: loki_index_
object_store: s3
schema: v13
store: tsdb
server:
grpc_listen_port: 9095
http_listen_port: 3100
http_server_read_timeout: 600s
http_server_write_timeout: 600s
log_level: info
storage_config:
bloom_shipper:
working_directory: /var/loki/data/bloomshipper
boltdb_shipper:
index_gateway_client:
server_address: dns+loki-index-gateway-headless.loki.svc.cluster.local:9095
hedging:
at: 250ms
max_per_second: 20
up_to: 3
tsdb_shipper:
tracing:
enabled: true
