Loki Logs not showing after some times, only last 3 hours logs are showing in grafana. im using loki 3.5.2 in k8 with external minio bucket as storage. below is my configurations. can anybody help with the issue. i require a log retention for 30days.
server:
http_listen_port: 3100
grpc_listen_port: 9095
http_server_read_timeout: 600s
http_server_write_timeout: 600s
# -- Limits config
limits_config:
reject_old_samples: true
max_cache_freshness_per_query: 10m
split_queries_by_interval: 15m
query_timeout: 300s
max_query_lookback: 720h
retention_period: 720h
volume_enabled: true
runtimeConfig: {}
commonConfig:
path_prefix: /var/loki
replication_factor: 3
compactor_address: '{{ include "loki.compactorAddress" . }}'
storage:
bucketNames:
chunks: "xyz-logging"
ruler: "xyz-logging"
admin: "xyz-logging"
type: s3
s3:
endpoint: "https://storage-api.xyzzyz.com"
secretAccessKey: "<>"
accessKeyId: "<>"
signatureVersion: "v4"
s3ForcePathStyle: true
insecure: false
http_config: {}
backoff_config: {}
disable_dualstack: false
filesystem:
chunks_directory: /var/loki/chunks
rules_directory: /var/loki/rules
admin_api_directory: /var/loki/admin
schemaConfig:
configs:
index:
prefix: index_
period: 24h
store: tsdb
object_store: s3
schema: v13
storage_config:
tsdb_shipper:
active_index_directory: /data/index
cache_location: /data/index_cache
s3:
bucketnames: xyz-logging
s3forcepathstyle: true
useTestSchema: false
testSchemaConfig:
configs:
store: tsdb
object_store: '{{ include "loki.testSchemaObjectStore" . }}'
schema: v13
index:
prefix: index_
period: 24h
rulerConfig:
wal:
dir: /var/loki/ruler-wal
structuredConfig: {}
query_scheduler: {}
compactor:
working_directory: /var/loki/data/retention
compaction_interval: 10m
retention_enabled: true
retention_delete_delay: 2h
retention_delete_worker_count: 30
delete_request_store: s3
pattern_ingester:
enabled: false
query_range: {}
querier:
max_concurrent: 4
ingester:
chunk_encoding: snappy
