Grafana-loki, querys dont show all log. Only about 2h
Hello, i’m stuck on configure Loki v 3.0. Please, can anyone explain me why Loki show only last 2h logs ? What configuration parameter i must set ?
Here is my config:
auth_enabled: false
chunk_store_config:
  chunk_cache_config:
    memcached:
      batch_size: 100
      parallelism: 100
    memcached_client:
      addresses: dns+grafana-loki-memcachedchunks:11211
      consistent_hash: true
common:
  compactor_address: http://grafana-loki-compactor:3100
compactor:
  delete_request_store: filesystem
  retention_enabled: true
  working_directory: /bitnami/grafana-loki/loki/retention
distributor:
  ring:
    kvstore:
      store: memberlist
frontend:
  compress_responses: true
  log_queries_longer_than: 5s
  tail_proxy_url: http://grafana-loki-querier:3100
frontend_worker:
  frontend_address: grafana-loki-query-frontend:9095
ingester:
  chunk_block_size: 262144
  chunk_encoding: snappy
  chunk_idle_period: 30m
  chunk_retain_period: 1m
  lifecycler:
    ring:
      kvstore:
        store: memberlist
      replication_factor: 1
  query_store_max_look_back_period: -1
  wal:
    dir: /bitnami/grafana-loki/wal
limits_config:
  max_entries_limit_per_query: 1000000
  max_query_length: 30d
  max_query_lookback: 672h
  max_query_range: 0
  retention_period: 672h
memberlist:
  join_members:
  - grafana-loki-gossip-ring
querier:
  max_concurrent: 16
  query_ingesters_within: 0
query_range:
  align_queries_with_step: true
  cache_results: true
  max_retries: 5
  results_cache:
    cache:
      memcached_client:
        addresses: dns+grafana-loki-memcachedfrontend:11211
        max_idle_conns: 16
        timeout: 500ms
        update_interval: 1m
query_scheduler:
  max_outstanding_requests_per_tenant: 32768
ruler:
  alertmanager_url: https://alertmanager.xx
  external_url: https://alertmanager.xx
  ring:
    kvstore:
      store: memberlist
  rule_path: /tmp/loki/scratch
  storage:
    local:
      directory: /bitnami/grafana-loki/conf/rules
    type: local
schema_config:
  configs:
    index:
      period: 24h
      prefix: index_
    object_store: filesystem
    schema: v13
    store: tsdb
server:
  grpc_listen_port: 9095
  http_listen_port: 3100
storage_config:
  filesystem:
    directory: /bitnami/grafana-loki/chunks
  index_queries_cache_config: null
  tsdb_shipper:
    active_index_directory: /bitnami/grafana-loki/loki/tsdb-index
    cache_location: /bitnami/grafana-loki/loki/tsdb-cache
table_manager:
  retention_deletes_enabled: false
  retention_period: 0s
I make query to loki gateway
curl -G -s “http://xxxxxxx/loki/api/v1/query_range”
–data-urlencode ‘query={container=“mongodb”}’
–data-urlencode “start=$(date -d ‘now - 24 hours’ ‘+%s’)”
–data-urlencode “end=$(date ‘+%s’)”| jq ‘.data.result.values’
and i got last log time record 2024-07-17T11:46:56.975+00:00
and first log time record 2024-07-17T12:17:58.877+00:00
or in grafana explore
why i cant see older logs ?
Are you running Loki as single binary?
No, i think it is like microservice Loki.
Then that’s your problem. You cannot use filesystem with microservice mode.
why? i must use minio s3 bucket ?
Thank you. That is my problem.
