We are unbale to see older logs more than 3 hrs even if we have set the retention period to 168h. Please help us with loki-loki-distributed config file where we can set configuration and see logs before 3hrs. This is the current setting we have in place.
limits_config:
deletion_mode: filter-and-delete
enforce_metric_name: false
ingestion_burst_size_mb: 20
ingestion_rate_mb: 10
max_cache_freshness_per_query: 10m
reject_old_samples: true
retention_period: 168h
split_queries_by_interval: 15m
- Make sure your chunk files are actually being written to your block storage.
- Make sure your queriers have permission to read from the block storage.
- Check querier logs for errors.
Also please share configuration.
Thank you for your reply. Sure here is the config for loki-loki-distributed.
Also we have this deployed in our AKS with loki-distributed helmchart
auth_enabled: false
chunk_store_config:
max_look_back_period: 0s
common:
compactor_address: http://loki-loki-distributed-compactor:3100
compactor:
retention_enabled: true
shared_store: azure
distributor:
ring:
kvstore:
store: memberlist
frontend:
compress_responses: true
log_queries_longer_than: 5s
tail_proxy_url: http://loki-loki-distributed-querier:3100
frontend_worker:
frontend_address: loki-loki-distributed-query-frontend-headless:9095
ingester:
chunk_block_size: 262144
chunk_encoding: snappy
chunk_idle_period: 30m
chunk_retain_period: 1m
lifecycler:
ring:
kvstore:
store: memberlist
replication_factor: 1
max_transfer_retries: 0
wal:
dir: /var/loki/wal
ingester_client:
grpc_client_config:
grpc_compression: gzip
limits_config:
memberlist:
join_members:
- loki-loki-distributed-memberlist
query_range:
align_queries_with_step: true
cache_results: true
max_retries: 5
results_cache:
cache:
embedded_cache:
enabled: true
ttl: 24h
ruler:
alertmanager_url: https://alertmanager.xx
external_url: https://alertmanager.xx
ring:
kvstore:
store: memberlist
rule_path: /tmp/loki/scratch
storage:
local:
directory: /etc/loki/rules
type: local
runtime_config:
file: /var/loki-distributed-runtime/runtime.yaml
schema_config:
configs:
index:
period: 24h
prefix: loki_index_
object_store: azure
schema: v11
store: boltdb-shipper
server:
http_listen_port: 3100
grpc_server_max_recv_msg_size: 104857600
grpc_server_max_send_msg_size: 104857600
storage_config:
azure:
account_key: ABCD
account_name: storageaccountname
container_name: loki
boltdb_shipper:
active_index_directory: /var/loki/index
cache_location: /var/loki/cache
cache_ttl: 168h
shared_store: filesystem
table_manager:
retention_deletes_enabled: false
retention_period: 0s
