As mentioned in title, log files are not show in dashboards or even explore if there is no constant activity in them.
Is there some configuration that enables or am I missing something?
That probably means your querier can’t get to your permanent storage. Share your Loki configuration please?
This is my current loki configuration. I think it’s too busy maybe there is way to keep it cleaner. In our monitoring setup we need retention for 1 year and I am saving data on the same server.
auth_enabled: false
server:
http_listen_port: 3100
http_server_write_timeout: 3m
http_server_read_timeout: 3m
grpc_server_max_recv_msg_size: 104857600 # 100 Mb
grpc_server_max_send_msg_size: 104857600 # 100 Mb
ingester_client:
grpc_client_config:
ingester:
chunk_encoding: snappy
chunk_idle_period: 1m
chunk_target_size: 1536000
max_chunk_age: 8760h
query_range:
split_queries_by_interval: 0
parallelise_shardable_queries: false
frontend_worker:
match_max_concurrent: true
grpc_client_config:
max_send_msg_size: 268435456
querier:
max_concurrent: 2048
frontend:
max_outstanding_per_tenant: 4096
compress_responses: true
common:
instance_addr: 0.0.0.0
path_prefix: /tmp/loki
storage:
filesystem:
chunks_directory: /tmp/loki/chunks
rules_directory: /etc/loki/rules # Adjust to your rules directory
replication_factor: 1
ring:
kvstore:
store: inmemory
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
compactor:
retention_enabled: true
limits_config:
split_queries_by_interval: 15m # Adjust as needed
reject_old_samples_max_age: 8760h
max_entries_limit_per_query: 10000 # Increase the limit
max_query_parallelism: 24 # Adjust based on your system's capacity
max_query_length: 8760h
ingestion_rate_mb: 64 # Increase the ingestion rate
ingestion_burst_size_mb: 128 # Increase the burst size
per_stream_rate_limit: "5MB" # Increase the per-stream rate limit
per_stream_rate_limit_burst: "20MB" # Increase the burst size
max_global_streams_per_user: 10000
deletion_mode: filter-and-delete
chunk_store_config:
max_look_back_period: 0
Had wrong paths. Changed paths for loki config and docker compose file and that fixed it.
