szhura
February 21, 2025, 1:50pm
1
logs delivered by promtail to loki looks deleted in 11 days - query doesn’t find them any more
here’s my /etc/loki/config.yml
auth_enabled: false
server:
http_listen_port: 3100
grpc_listen_port: 9096
log_level: error
grpc_server_max_concurrent_streams: 1000
common:
instance_addr: 172.20.0.239
path_prefix: /tmp/loki
storage:
filesystem:
chunks_directory: /tmp/loki/chunks
rules_directory: /tmp/loki/rules
replication_factor: 1
ring:
kvstore:
store: inmemory
ingester_rf1:
enabled: false
query_range:
results_cache:
cache:
embedded_cache:
enabled: true
max_size_mb: 100
compactor:
working_directory: /tmp/loki/retention
compaction_interval: 15m
retention_enabled: false
retention_delete_delay: 1h
retention_delete_worker_count: 50
delete_request_store: filesystem
schema_config:
configs:
store: tsdb
object_store: filesystem
schema: v13
index:
prefix: index_
period: 24h
limits_config:
ingestion_rate_mb: 4
ingestion_burst_size_mb: 6
reject_old_samples: true
reject_old_samples_max_age: 3w
retention_period: 672h
pattern_ingester:
enabled: true
metric_aggregation:
enabled: true
loki_address: localhost:3100
ruler:
alertmanager_url: http://localhost:9093
frontend:
encoding: protobuf
what am i doing wrong?
Don’t see anything obvious. Couple of things to try:
Are you sure logs are deleted? check your filesystem for Loki storage and see if there are files older than 11 days.
Are you running Docker? Is the storage mounted properly from host?
Do you have any sort of cronjob that’s doing cleanup outside of Loki for your filesystem?
Do you see logs from compactor that files were deleted?
szhura
February 24, 2025, 8:44am
3
thank you for answer. let’s see…
you’re right! in storage i’ve found files 17-days old. with data. but explore in grafana doesn’t show it. directory /tmp/loki/chunks/fake contains 909054 directories. everyday near 12:00 like 11:56-11:57 i see thousands of directories created in one minute and they all are empty…
no docker. no
no cronjobs. at least i didn’t make any. /etc/crontab is empty
i don’t know how to find compactor logs
szhura
March 6, 2025, 9:03am
4
help still needed. anyone some ideas?
szhura
March 11, 2025, 11:10am
5
i’ve disabled compactor like “retention_enabled: false” but nothing changed - explore still cannot find data older than 11 days
szhura
April 14, 2025, 11:58am
6
i’ve tried:
pattern_ingester:
enabled: true
metric_aggregation:
enabled: true
lifecycler:
ring:
replication_factor: 3
but! messages tell me:
Apr 14 14:41:40 hmax-loki loki[7801]: level=error ts=2025-04-14T11:41:40.666422684Z caller=main.go:70 msg=“validating config” err=“CONFIG ERROR: invalid pattern_ingester config: pattern ingester replication factor must be 1”
must be 1 ??? why this setting exist really? and how to increase number of ingesters? it seemes that loki cannot handle logs - error 429 occurs
and how does it comply with Grafana Loki configuration parameters | Grafana Loki documentation :
# The number of ingesters to write to and read from.
# CLI flag: -distributor.replication-factor
[replication_factor: <int> | default = 3]
szhura
April 28, 2025, 6:18am
7
so i did a fresh install from the begining. without compactor at all. logs are still 11-days only…
new config:
Summary
auth_enabled: false
server:
log_level: error
common:
instance_addr: 172.20.0.238
storage:
filesystem:
ring:
kvstore:
store: inmemory
query_range:
results_cache:
cache:
embedded_cache:
enabled: true
max_size_mb: 100
limits_config:
metric_aggregation_enabled: true
schema_config:
configs:
store: tsdb
schema: v13
index:
prefix: index_
period: 24h
pattern_ingester:
enabled: true
metric_aggregation:
ruler:
frontend:
encoding: protobuf
and output of http://172.20.0.238:3100/config :
config.json (75.9 KB)
json because txt not allowed…
what is wrong with loki??? :(((
szhura
April 28, 2025, 6:31am
8
here’s data directory info:
Summary
[root@hmax-loki2 ~]# find /tmp/loki/chunks/fake -type f | wc -l
745491
[root@hmax-loki2 ~]# find /tmp/loki/chunks/fake -type d | wc -l
929240
[root@hmax-loki2 ~]# df -a
proc 0 0 0 - /proc
sysfs 0 0 0 - /sys
devtmpfs 4096 0 4096 0% /dev
securityfs 0 0 0 - /sys/kernel/security
tmpfs 4065052 0 4065052 0% /dev/shm
devpts 0 0 0 - /dev/pts
tmpfs 1626024 18728 1607296 2% /run
cgroup2 0 0 0 - /sys/fs/cgroup
pstore 0 0 0 - /sys/fs/pstore
efivarfs 256 27 225 11% /sys/firmware/efi/efivars
bpf 0 0 0 - /sys/fs/bpf
/dev/mapper/cs-root 157220864 9942764 147278100 7% /
systemd-1 - - - - /proc/sys/fs/binfmt_misc
debugfs 0 0 0 - /sys/kernel/debug
mqueue 0 0 0 - /dev/mqueue
hugetlbfs 0 0 0 - /dev/hugepages
tracefs 0 0 0 - /sys/kernel/tracing
none 0 0 0 - /run/credentials/systemd-tmpfiles-setup-dev.service
fusectl 0 0 0 - /sys/fs/fuse/connections
configfs 0 0 0 - /sys/kernel/config
none 0 0 0 - /run/credentials/systemd-sysctl.service
/dev/sda2 983040 272424 710616 28% /boot
/dev/sda1 613160 7652 605508 2% /boot/efi
none 0 0 0 - /run/credentials/systemd-tmpfiles-setup.service
binfmt_misc 0 0 0 - /proc/sys/fs/binfmt_misc
tmpfs 813008 0 813008 0% /run/user/0
lots of empty directories appeared in the last 3 days in chunks dir and logs from 14-11 days are no longer…
disk usage of / is 7%
Hi @szhura ,
Please try adding the following to your configuration.
table_manager:
retention_deletes_enabled: true
szhura
May 12, 2025, 8:53am
11
nothing changed :,(
today logs ending at 17-00 may-01-2025
config1.json (73.0 KB)
here’s new config
szhura
May 21, 2025, 8:49am
12
maybe the problem is in centos9 ??? somehow…
szhura
May 26, 2025, 9:20am
13
what mechanizm in loki or grafana can delete data from db/filesystem ?
i mean - besides retention?
szhura
June 17, 2025, 11:02am
14
maybe exist esxi image with installed grafana-loki stack?
hi bro,
you have any update here i ‘m in same issues log disappear after 10d
my config is:
auth_enabled: false
bloom_build:
builder:
planner_address: ""
enabled: false
bloom_gateway:
client:
addresses: ""
enabled: false
chunk_store_config:
chunk_cache_config:
background:
writeback_buffer: 500000
writeback_goroutines: 1
writeback_size_limit: 500MB
default_validity: 0s
memcached:
batch_size: 4
parallelism: 5
memcached_client:
addresses: dnssrvnoa+_memcached-client._tcp.loki-chunks-cache.platform-logging.svc
consistent_hash: true
max_idle_conns: 72
timeout: 2000ms
common:
compactor_address: 'http://loki:3100'
path_prefix: /var/loki
storage:
s3:
access_key_id: root
bucketnames: chunks
endpoint: loki-minio.platform-logging.svc:9000
insecure: true
s3forcepathstyle: true
secret_access_key: xxxx
compactor:
delete_request_store: s3
retention_enabled: true
working_directory: /var/loki/compactor
frontend:
scheduler_address: ""
tail_proxy_url: ""
frontend_worker:
index_gateway:
mode: simple
limits_config:
ingestion_burst_size_mb: 150
ingestion_rate_mb: 100
max_cache_freshness_per_query: 10m
max_query_series: 15000
per_stream_rate_limit: 256M
per_stream_rate_limit_burst: 512M
query_timeout: 300s
retention_period: 720h
split_queries_by_interval: 15m
volume_enabled: true
memberlist:
join_members:
- loki-memberlist
pattern_ingester:
enabled: true
query_range:
align_queries_with_step: true
cache_results: true
results_cache:
cache:
background:
default_validity: 12h
memcached_client:
addresses: dnssrvnoa+_memcached-client._tcp.loki-results-cache.platform-logging.svc
timeout: 500ms
update_interval: 1m
ruler:
storage:
s3:
bucketnames: ruler
type: s3
wal:
dir: /var/loki/ruler-wal
runtime_config:
file: /etc/loki/runtime-config/runtime-config.yaml
schema_config:
configs:
index:
period: 24h
prefix: index_
object_store: 's3'
schema: v13
store: tsdb
server:
grpc_listen_port: 9095
http_server_read_timeout: 600s
http_server_write_timeout: 600s
storage_config:
bloom_shipper:
working_directory: /var/loki/data/bloomshipper
boltdb_shipper:
index_gateway_client:
server_address: ""
hedging:
at: 250ms
max_per_second: 20
up_to: 3
tsdb_shipper:
server_address: ""
tracing:
enabled: false
Thank you!
