Promtail example-static-config
When using tihs example to collect logs, this configuration doesn’t work (Configure Promtail | Grafana Loki documentation)
scrape_configs:
 - job_name: system
   pipeline_stages:
   static_configs:
   - targets:
      - localhost
     labels:
      job: varlogs  # A `job` label is fairly standard in prometheus and useful for linking metrics and logs.
      host: yourhost # A `host` label will help identify logs from this machine vs others
      __path__: /var/log/*.log
I use extraScrapeConfigs to collect the log successfully
What is the difference between the two configurations?
I also needed to define extraVolumes to use extraScrapeConfigs.
Example:
extraVolumes:
  • name: node-logs
    hostPath:
    path: /var/log
extraVolumeMounts:
  • name: node-logs
    mountPath: /var/log
    readOnly: true
Set fsGroup to allow syslog file reading
podSecurityContext:
fsGroup: 4
Allow environment variables usage
extraArgs:
  • -config.expand-env=true
Scrape config to read syslog file from node
ls -1 /var/log/{,/}{[._]log,{mail,news}.{err,info,warn}}
var/log all files => path: /var/log/{,*/}
config:
snippets:
extraScrapeConfigs: |
# Add an additional scrape config for syslog
- job_name: node-all
static_configs:
- targets:
- localhost
labels:
job: node/node-all
path: /var/log/syslog
node_name: ‘onap-grafana-loki’
