sni
1
is there any best practice for using static_configs for multiple files. I want to tail multiple logfiles from various locations.
This one works:
scrape_configs:
- job_name: grafana
entry_parser: raw
static_configs:
- targets:
- localhost
labels:
__path__: var/log/{loki,promtail}.log
job: omd
But it does not work when i try to include folders like:
__path__: var/log/{loki,promtail,grafana/grafana}.log
Promtail simply ignores that entry completly.
__path__: /var/log/*.log # The path matching uses a third party library: https://github.com/bmatcuk/doublestar
try this path
__path__: var/log/**/{loki,promtail,grafana}.log
if the log is in a different location, do I need to add another target? it’s not possible to do like this?
labels:
__path__:
- var/log/{loki,promtail}.log
- /var/log/smth/file.log
Hi, @yuswanulherlan . Did the YAML list on the __path__ attribute work?
no, it’s not.
i need to create another entry of target and set the job and the path
^ That works for me ( path: var/log/**/{syslog,kern}.log )
