PromQL sum several query with variable filters -> No data
    Grafana v11.6.5 (7d067d343a)
    I have a query where I try to add several measurements with variable filters.
    (sum(EatonG3_Branch_1_Current_L1{ca=~“$CA”, busbar=~“$Busbar”, rack=~“$Rack”}) by (busbar))
    (sum(EatonG3_Branch_4_Current_L1{ca=~“$CA”, busbar=~“$Busbar”, rack=~“$Rack”}) by (busbar))
    (sum(EatonG3_Branch_2_Current_L1{ca=~“$CA”, busbar=~“$Busbar”, rack=~“$Rack”}) by (busbar))
  • What happened?
    When one measurement is not available it results in No data.
    Just to add all different values per busbar
    see How
    Just no data (since one value is not always available, it depens on type of measurement device used on the filtering
    I tried Copilot :slight_smile:
    I tried add vector (0) but without succes.
