Grafana v10.1.1
Ubuntu 22.04
I am trying to add a ‘Stat’ visualization which sums stats from a handful of measurements, some of which may have no data for a given requestId (see below).
I have the following measurements: m1, m2, m3, m4, m5
Each measurement has a field “execTime”
Each measurement has a tag “requestId”
For the visualization I have 5 different queries SELECT "execTime" FROM <measurement> WHERE requestId = ${requestId}
Finally I have an expression that adds all the results together
Operation: Math
Expression: $A + $B + $C + $D + $E
What happened?
My stat displays “No Data”
It would display the sum of all the queries, excluding any that return “No Data”
I don’t think that is neccessary here, but maybe, if needed
No errors, just odd behavior
No
I think you don’t understand my query example - one query selects X different request ids and calculate their SUM on the SQL level - there is no need of X queries (and other Grafana related problems, e.g. “how do I add the result of these 5 queries together”).
