Problem with debian repository key
Hi to everyone.
apt is complaining about a missing public key
Errore:1 https://apt.grafana.com stable InRelease
  Le seguenti firme non sono state verificate perché la chiave pubblica non è disponibile: NO_PUBKEY 9E439B102CF3C0C6
but the key is there:
gpg --show-keys /usr/share/keyrings/grafana.gpg
pub   rsa3072 2023-01-06 [SC] [scadenza: 2025-01-05]
      0E22EB88E39E12277A7760AE9E439B102CF3C0C6
uid                      Grafana Labs <engineering@grafana.com>
sub   rsa3072 2023-01-06 [E] [scadenza: 2025-01-05]
My grafana.list is:
cat /etc/apt/sources.list.d/grafana.list
deb [signed-by=/usr/share/keyrings/grafana.gpg] https://apt.grafana.com stable main
What am I missing?
The key was emergency-rotated, as fallout from the CircleCI breach.
Whenever there’s a key problem with the repo signing key, I’ve found it best to check https://packages.grafana.com/oss/ – there’s usually something useful there. In this case:
The GPG key used to sign the APT repository (fingerprint 4E40DDF6D76E284A4A6780E48C8C34C524098CB6) was rotated on 2023-01-12 and replaced with a new key with fingerprint 0E22EB88E39E12277A7760AE9E439B102CF3C0C6.
If you enabled the repository before that, you will see errors when running apt update.
To fix this, re-run the commands below to fetch the new key. See the following blog post for more information: Grafana Labs update regarding CircleCI security updates | Grafana Labs
(I had to stop there, I’ve not used the community pages from this account before so hit a new-user 2-links limit)
Thanks for your answer.
I had already found the news about the key rotation and downloaded the new key, please see the fingerprint posted in my previous message.
But I still get an error from apt, and the error message is pointing to new key:
EDIT: ok I was missing the command gpg --dearmor on the key, now it works
Can you explain the exact command because I have the same issue
From link posted by ptpdp before:
$ mkdir -p /etc/apt/keyrings/
$ wget -q -O - https://apt.grafana.com/gpg.key | gpg --dearmor > /etc/apt/keyrings/grafana.gpg
$ echo "deb [signed-by=/etc/apt/keyrings/grafana.gpg] https://apt.grafana.com stable main" | tee /etc/apt/sources.list.d/grafana.list
neither these command nor the ones from the blog actually work for me (Ubuntu).
EDIT:
it seems for ubuntu 20.04 the gpg key must be put into /etc/apt/trusted.gpg.d
else it simply does not work
Greetings all, noob here. Just inherited this from someone else.
For me what worked is the link sent by @ptpdp
In case someone needs a fix without going around circles…
For anyone on Raspberry pi, the commands that will solve the problem are:
cd /etc/apt/trusted.gpg.d/
sudo wget -q -O - https://apt.grafana.com/gpg.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/grafana.gpg >/dev/null
echo "deb [signed-by=/etc/apt/trusted.gpg.d/grafana.gpg] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
Thamks :smiley:
