Upgrade - Public key is not available error
I am trying to upgrade from V5.0 to the current version V5.4 on my Raspberry running Debian.
So I run this command
sudo apt-get update
then this
sudo apt-get install grafana
and I successfully upgraded to V5.1.4. Not the current version but a new version.
I then try to run the the following command again
sudo apt-get update
but this time I get this error
Get:7 https://packagecloud.io/grafana/stable/debian jessie InRelease [23.4 kB]
Err:7 https://packagecloud.io/grafana/stable/debian jessie InRelease
The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 40F370A1F9081B64
So I tried this
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv 40F370A1F9081B64
and get the following error.
Executing: /tmp/apt-key-gpghome.v4j7teiNJK/gpg.1.sh --keyserver hkp://keyserver.ubuntu.com:80 --recv 40F370A1F9081B64
gpg: keyserver receive failed: No data
I have tried a few different versions of this command but same problem and I can’t get any further with the upgrade.
Does anybody have and ideas on how to fix this ?
Thanks
Paul
the package repository has changed: https://grafana.com/blog/2019/01/05/moving-to-packages.grafana.com/
Thanks
I was able to upgrade.
I still get an error as it looks for the old packages. Is there a way to stop this error. I changed the grafana.list file to deb https://packages.grafana.com/oss/deb stable main.
pi@raspberrypi:/etc/apt/sources.list.d $ sudo apt-get update
Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
Hit:2 http://mirrordirector.raspbian.org/raspbian stretch InRelease
Hit:3 https://deb.nodesource.com/node_8.x stretch InRelease
Hit:4 https://repos.influxdata.com/debian jessie InRelease
Hit:6 https://packages.grafana.com/oss/deb stable InRelease
Get:5 https://packagecloud.io/grafana/stable/debian jessie InRelease [23.4 kB]
Err:5 https://packagecloud.io/grafana/stable/debian jessie InRelease
Fetched 23.4 kB in 7s (2,971 B/s)
Reading package lists… Done
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packagecloud.io/grafana/stable/debian jessie InRelease: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 40F370A1F9081B64
W: Failed to fetch https://packagecloud.io/grafana/stable/debian/dists/jessie/InRelease The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 40F370A1F9081B64
W: Some index files failed to download. They have been ignored, or old ones used instead.
Solved. Had to edit sources.list to remove link to old repository. Not sure why it was there but api-get update works without error now.
pi@raspberrypi:/etc/apt $ sudo apt-get update
Hit:3 https://repos.influxdata.com/debian jessie InRelease
Hit:4 https://deb.nodesource.com/node_8.x stretch InRelease
Hit:5 https://packages.grafana.com/oss/deb stable InRelease
Could you please show how to edit the source list?
I am using debian 9 on a laptop, notraspi. But I cannot find how to do it.
Thanx.
