Trying to Upgrade from 9.4.3 to latest version, Getting Public Key Error
So I’m trying to upgrade from 9.4.3 to the latest version of Grafana on a RPi 4 running Bullseye but I keep getting the following error.
Err:5 https://packages.grafana.com/oss/deb stable InRelease
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
Reading package lists... Done
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
I found other postings about fixing this issue, and tried them, but still no luck.
The key file I have is /etc/apt/keyrings/grafana.gpg
The package list is as follows…
/etc/apt/sources.list.d/grafana.list
deb https://packages.grafana.com/oss/deb stable main
deb [signed-by=/etc/apt/keyrings/grafana.gpg] https://apt.grafana.com stable main
That seem correct, but apparently it isn’t. Sure could use some help on getting upgraded…
hi @skcamdam
have you tried:
mkdir -p /etc/apt/keyrings/
wget -q -O - https://apt.grafana.com/gpg.key | gpg --dearmor > /etc/apt/keyrings/grafana.gpg
echo "deb [signed-by=/etc/apt/keyrings/grafana.gpg] https://apt.grafana.com stable main" | tee /etc/apt/sources.list.d/grafana.list
Here’s a similar case:
