Problem installing Grafana on Lenovo w. Raspbian - Architektur »i386« nicht unterstützt
    HW: Lenovo T410 setup w. Rasbpian OS:
    uname -a
    Linux raspc 5.10.0-20-amd64 #1 SMP Debian 5.10.158-2 (2022-12-13) x86_64 GNU/Linux
    System is working, installed ssh, XRDB Service, samba, apache2, mariadb, phpmyadmin (some test tables filled), all working ok.
    Installed latest enterprice version (apt) according to
    Install on Debian or Ubuntu | Grafana documentation
    AS NEW USER I AM NOT ALLOWED TO use morethan 2 URLS,
    THEREFOIRE I replaces the https: by … in commands below
sudo apt-get install -y apt-transport-https
sudo apt-get install -y software-properties-common wget
sudo wget -q -O /usr/share/keyrings/grafana.key ...... /apt.grafana.com/gpg.key
and the stable release:
echo "deb [signed-by=/usr/share/keyrings/grafana.key] .... apt.grafana.com stable main" | sudo tee -a /etc/apt/sources.list.d/grafana.list
  • What happened?
starting
sudo apt-get update
reported that grafanain»main/binary-i386/Packages« does not support architecture i386:
OK:1 …/deb.debian.org/debian bullseye InRelease
Holen:2 … /deb.debian.org/debian-security bullseye-security InRelease [48,4 kB]
OK:3 …/archive.raspberrypi.org/debian bullseye InRelease
OK:4 …/deb.debian.org/debian bullseye-updates InRelease
OK:5 …/apt.grafana.com stable InRelease
Es wurden 48,4 kB in 1 s geholt (48,9 kB/s).
Paketlisten werden gelesen… Fertig
N: Das Laden der konfigurierten Datei »main/binary-i386/Packages« wird übersprungen, da das Depot »…/apt.grafana.com stable InRelease« die Architektur »i386« nicht unterstützt.
??? is this ok???
Then I installed the package by
sudo apt-get install grafana-enterprise
all seemed to be ok, BUT
commands for starting also seemed ok:
sudo systemctl daemon-reload
sudo systemctl start grafana-server
BUT:
sudo systemctl status grafana-server
reported:
● grafana-server.service - Grafana instance
Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
Active: failed (Result: signal) since Thu 2023-01-05 19:35:49 CET; 2h 46min ago
Docs: …/docs.grafana.org
Process: 3516 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-serve>
Main PID: 3516 (code=killed, signal=SYS)
CPU: 50ms
Jan 05 19:35:49 raspc systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
Jan 05 19:35:49 raspc systemd[1]: Stopped Grafana instance.
Jan 05 19:35:49 raspc systemd[1]: grafana-server.service: Start request repeated too quickly.
Jan 05 19:35:49 raspc systemd[1]: grafana-server.service: Failed with result ‘signal’.
Jan 05 19:35:49 raspc systemd[1]: Failed to start Grafana instance.
Jan 05 19:35:53 raspc systemd[1]: grafana-server.service: Start request repeated too quickly.
Jan 05 19:35:53 raspc systemd[1]: grafana-server.service: Failed with result ‘signal’.
Jan 05 19:35:53 raspc systemd[1]: Failed to start Grafana instance.
    There was NO log in /var/log/grafana/ (empty directory)
    official grafana page at docs/grafana/latest/setup-grafana/installation/debian/
BTW: All dirs and files mentionned in above URL at “Package details”
seem to be there.
Any Idea what is the problem???
Thanks for support!!!
You have systemd, so I guess journalctl manages your logs. Check logs with the command:
journalctl -u grafana-server
Thanks for quick answer.
That’s what I also already checked, but with no additional Info:
Have a nice day,
Klaus
Jan 05 19:35:48 raspc systemd[1]: grafana-server.service: Main process exited, code=killed, status=31/SYS
Jan 05 19:35:48 raspc systemd[1]: grafana-server.service: Failed with result ‘signal’.
Jan 05 19:35:49 raspc systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 4.
Jan 05 19:35:49 raspc systemd[1]: Started Grafana instance.
Jan 05 19:35:49 raspc systemd[1]: grafana-server.service: Main process exited, code=killed, status=31/SYS
What I wonder is that
sudo apt-get update
reports error in Depot »https://apt.grafana.com stable InRelease«
while
more /etc/apt/sources.list.d/grafana.list
deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main
This (stable main <-----> In Release) is ok???
I guess you have old systemd, where some new features are missing. Grafana instance fails to start - #2 by wnasich
shouldn’t systemd be the newest one when I do
sudo apt-get update
sudo apt-get upgrade
BEFORE each new installation of a tool???
actual grafana version I try to install is grafana-enterprise_9.3.2_amd64.deb
systemd version is: 247 (247-3.7+deb11u1)
Especially I wonder why - when installing according the grafana install docu for APT and I do:
apt-get update
it reports not to do the load of configured »main/binary-i386/Packages« as not supporting i386 architecture:
Does this mean that apt tries to get a wrong image???
In addition (not reported in full description above) I tried the installation for DEBIAN according to the description here:
Same result for Debian installation L
Here I was not quite sure if I had to install Debian or an x86 (CentOS,…) installation:
As uname –a says:
But trying to install the x86 version did not succeed and reported to be awrong image.
