Raspberry Pi B+ ARMv6 - working installation?
Hello Everyone,
I am quite new to Grafana and its applications. I am currently struggling setting up an Grafana Installation on an old Raspberry pi B+ (Thats what I currently have lying around)
I tried the offical installation via the Grafana Documentation and I tried the Installation for Debain ARMv6 - both didn’t work for me.
So my question: Has anyone a version of Grafana running on an old Pi?
thanks in advance!
Luke
It would probably help greatly if you would elaborate on “both didn’t work
for me”.
Which part of the installation failed? How did it fail (what errors were
displayed)?
If the installation succeeded but you could not then start Grafana, how did
you try to start it, and once again, what errors were displayed (either on the
screen or in log files)?
I recommend you also tell us:
  1. What’s the output of “uname -a” on this Pi?
  2. Which package repository did you get Grafana from (ie: what did you put
    into /etc/apt/sources.list.d/grafana.list or whatever you called it)?
Antony.
Sorry for beeing incomplete.
Installation 1: Fresh Setup of the Raspberry with: Install Grafana on Raspberry Pi | Grafana Labs
I read somewhere that this Installation is not working on the ARMv6 architecture.
Thus - Installation 2: Download Grafana | Grafana Labs
I used Debain/Ubuntu ARMv6.
On the latest installation I checked also with systemctl start grafana-server and it stated that the server is running.
Looking into the log I can see that it is rebooting all the time due to a error. I still haven’t looked through the whole log-file and traced down the error.
I will post the Log-file and further informations tomorrow.
cheers!
Allright:
I used the following 2 guides/repositories:
Repository 1: https://packages.grafana.com/oss/deb stable main
Repository 2: https://dl.grafana.com/enterprise/release/grafana-enterprise-rpi_9.3.2_armhf.deb
Output of “uname -a”: Linux raspberrypi 5.15.84+ #1613 Thu Jan 5 11:58:09 GMT 2023 armv6l GNU/Linux
Jan 18 16:55:27 raspberrypi systemd[1]: Stopped Grafana instance.
Jan 18 16:55:27 raspberrypi systemd[1]: grafana-server.service: Consumed 10.332s CPU time.
Jan 18 16:55:27 raspberrypi systemd[1]: Started Grafana instance.
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.637383871+01:00 level=info msg=“Starting Grafana” version=9.3.2 commit=21c1d14e91 branch=HEAD compiled=2022-12-14T11:40:18+01:00
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.674781411+01:00 level=info msg=“Config loaded from” file=/usr/share/grafana/conf/defaults.ini
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.680724338+01:00 level=info msg=“Config loaded from” file=/etc/grafana/grafana.ini
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.685927274+01:00 level=info msg=“Config overridden from command line” arg=“default.paths.data=/var/lib/grafana”
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.714391923+01:00 level=info msg=“Config overridden from command line” arg=“default.paths.logs=/var/log/grafana”
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.720958842+01:00 level=info msg=“Config overridden from command line” arg=“default.paths.plugins=/var/lib/grafana/plugins”
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.753992435+01:00 level=info msg=“Config overridden from command line” arg=“default.paths.provisioning=/etc/grafana/provisioning”
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.75930937+01:00 level=info msg=“Path Home” path=/usr/share/grafana
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.764496306+01:00 level=info msg=“Path Data” path=/var/lib/grafana
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.765191297+01:00 level=info msg=“Path Logs” path=/var/log/grafana
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.766059287+01:00 level=info msg=“Path Plugins” path=/var/lib/grafana/plugins
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.766784278+01:00 level=info msg=“Path Provisioning” path=/etc/grafana/provisioning
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.767466269+01:00 level=info msg=“App mode production”
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=sqlstore t=2023-01-18T16:55:37.78525805+01:00 level=info msg=“Connecting to DB” dbtype=sqlite3
Jan 18 16:55:37 raspberrypi grafana-server[1116]: unexpected fault address 0x3da2558
Jan 18 16:55:37 raspberrypi grafana-server[1116]: fatal error: fault
Jan 18 16:55:37 raspberrypi grafana-server[1116]: [signal SIGSEGV: segmentation violation code=0x2 addr=0x3da2558 pc=0x28e88f8]
Jan 18 16:55:37 raspberrypi grafana-server[1116]: goroutine 1 [running]:
Jan 18 16:55:37 raspberrypi grafana-server[1116]: runtime.throw({0x32a8b7d, 0x5})
Jan 18 16:55:37 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/panic.go:1047 +0x4c fp=0x789f3a4 sp=0x789f390 pc=0x5c8d4
Jan 18 16:55:37 raspberrypi grafana-server[1116]: runtime.sigpanic()
Jan 18 16:55:37 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/signal_unix.go:842 +0x1d0 fp=0x789f3bc sp=0x789f3a4 pc=0x766c0
Jan 18 16:55:37 raspberrypi grafana-server[1116]: runtime: g 1: unexpected return pc for _cgo_topofstack called from 0xa6b22424
Jan 18 16:55:37 raspberrypi grafana-server[1116]: stack: frame={sp:0x789f3c0, fp:0x789f3cc} stack=[0x7880000,0x78a0000)
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f340: 0x0005ea14 <runtime.gwrite+0x00000034> 0x0005eac4 <runtime.gwrite+0x000000e4> 0x00000002 0x03ad5ee4
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f350: 0x00000001 0x00000001 0x0005f2e0 <runtime.printstring+0x00000060> 0x00000002
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f360: 0x03ad5ee4 0x00000001 0x00000001 0x000931e4 <runtime.systemstack+0x0000004c>
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f370: 0x0005cbb8 <runtime.fatalthrow+0x00000064> 0x0005c8d4 <runtime.throw+0x0000004c> 0x0789f380 0x06c020f0
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f380: 0x0005cbd0 <runtime.fatalthrow.func1+0x00000000> 0x06c020f0 0x0005c8d4 <runtime.throw+0x0000004c> 0x0789f390
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f390: 0x000766c0 <runtime.sigpanic+0x000001d0> 0x00000002 0x0005c8e0 <runtime.throw.func1+0x00000000> 0x032a8b7d
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f3a0: 0x00000005 0x00094dfc <_cgo_topofstack+0x00000010> 0x032a8b7d 0x00000005
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f3b0: 0x00094dfc <_cgo_topofstack+0x00000010> 0x03da2558 0x06c020f0 0x00094dfc <_cgo_topofstack+0x00000010>
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f3c0: <0xa6b22424 0x02095260 <github### . removed due to link restriction# com/grafana/grafana/pkg/extensions/caching.AddMigration+0x00000d78> 0x071ab5c0 >0x0000002e
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f3d0: 0x03afdac4 0x06ca4258 0x00000000 0x00000000
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f3e0: 0x00000000 0x071ab598 0x00000001 0x00000001
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f3f0: 0x06ca4228 0x071625c0 0x00000002 0x00000000
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f400: 0x00000006 0x00d24248 <github### . ### com/grafana/grafana/pkg/services/sqlstore/migrator.(*Migrator).AddMigration+0x00000148> 0x072fb200 0x138b1414
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f410: 0x06ca4258 0x06ca4240 0x07162600 0x071625e0
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f420: 0x2b4f4832 0x06daeab0 0x06daea80 0x06ca4268
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f430: 0x032a488f 0x06ca4210 0x06ca4270 0x071ab598
Jan 18 16:55:38 raspberrypi grafana-server[1116]: 0x0789f440: 0x06ca4210 0x06ed4c20 0x03344b91
Jan 18 16:55:38 raspberrypi grafana-server[1116]: _cgo_topofstack()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:820 +0x10 fp=0x789f3cc sp=0x789f3c0 pc=0x94dfc
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 2 [force gc (idle)]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.gopark(0x34e5f50, 0x573a090, 0x11, 0x14, 0x1)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:363 +0x100 fp=0x6c5afd8 sp=0x6c5afc4 pc=0x5fd8c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.goparkunlock(…)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:369
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.forcegchelper()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:302 +0xc4 fp=0x6c5afec sp=0x6c5afd8 pc=0x5fbf0
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.goexit()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c5afec sp=0x6c5afec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: created by runtime.init.5
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:290 +0x1c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 3 [runnable]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.Gosched(…)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:318
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.bgsweep(0x6c78000)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mgcsweep.go:283 +0x13c fp=0x6c5b7e4 sp=0x6c5b7d0 pc=0x471fc
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.gcenable.func1()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mgc.go:178 +0x28 fp=0x6c5b7ec sp=0x6c5b7e4 pc=0x37830
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c5b7ec sp=0x6c5b7ec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: created by runtime.gcenable
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mgc.go:178 +0x74
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 4 [GC scavenge wait]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.gopark(0x34e5f50, 0x5740330, 0xd, 0x14, 0x2)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:363 +0x100 fp=0x6c5bfb4 sp=0x6c5bfa0 pc=0x5fd8c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.(*scavengerState).park(0x5740330)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mgcscavenge.go:389 +0x64 fp=0x6c5bfc8 sp=0x6c5bfb4 pc=0x44be4
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.bgscavenge(0x6c78000)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mgcscavenge.go:622 +0x64 fp=0x6c5bfe4 sp=0x6c5bfc8 pc=0x45338
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.gcenable.func2()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mgc.go:179 +0x28 fp=0x6c5bfec sp=0x6c5bfe4 pc=0x377dc
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c5bfec sp=0x6c5bfec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mgc.go:179 +0xbc
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 5 [finalizer wait]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.gopark(0x34e5f50, 0x581d954, 0x10, 0x14, 0x1)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:363 +0x100 fp=0x6c5a78c sp=0x6c5a778 pc=0x5fd8c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.runfinq()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mfinal.go:180 +0x108 fp=0x6c5a7ec sp=0x6c5a78c pc=0x36870
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c5a7ec sp=0x6c5a7ec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: created by runtime.createfing
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mfinal.go:157 +0x54
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 18 [GC worker (idle)]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.gopark(0x34e5e10, 0x6c4a978, 0x18, 0x14, 0x0)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:363 +0x100 fp=0x6c5c790 sp=0x6c5c77c pc=0x5fd8c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.gcBgMarkWorker()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mgc.go:1235 +0x100 fp=0x6c5c7ec sp=0x6c5c790 pc=0x3a448
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c5c7ec sp=0x6c5c7ec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: created by runtime.gcBgMarkStartWorkers
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mgc.go:1159 +0x20
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 28 [chan receive]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.gopark(0x34e5ddc, 0x6d00670, 0xe, 0x17, 0x2)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:363 +0x100 fp=0x6c5cf5c sp=0x6c5cf48 pc=0x5fd8c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.chanrecv(0x6d00640, 0x6c5cfd0, 0x1)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/chan.go:583 +0x530 fp=0x6c5cfa8 sp=0x6c5cf5c pc=0x20828
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.chanrecv2(0x6d00640, 0x6c5cfd0)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/chan.go:447 +0x20 fp=0x6c5cfbc sp=0x6c5cfa8 pc=0x202ec
Jan 18 16:55:38 raspberrypi grafana-server[1116]: github###.###com/golang/glog.(*loggingT).flushDaemon(0x57401e8)
Jan 18 16:55:38 raspberrypi systemd[1]: grafana-server.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/opt/drone/gomodcache/github.com/golang/glog@v1.0.0/glog.go:882 +0x70 fp=0x6c5cfe4 sp=0x6c5cfbc pc=0x102fdd0
Jan 18 16:55:38 raspberrypi grafana-server[1116]: github###.###com/golang/glog.init.0.func1()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/opt/drone/gomodcache/github.com/golang/glog@v1.0.0/glog.go:410 +0x28 fp=0x6c5cfec sp=0x6c5cfe4 pc=0x102e114
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c5cfec sp=0x6c5cfec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: created by github###.###com/golang/glog.init.0
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/opt/drone/gomodcache/github.com/golang/glog@v1.0.0/glog.go:410 +0x210
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 98 [select]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.gopark(0x34e5f7c, 0x0, 0x9, 0x18, 0x1)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:363 +0x100 fp=0x6c576ec sp=0x6c576d8 pc=0x5fd8c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.selectgo(0x6c577cc, 0x6c577b8, 0x0, 0x0, 0x3, 0x1)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/select.go:328 +0xb64 fp=0x6c57794 sp=0x6c576ec pc=0x72a1c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: go###.###opencensus###.io/stats/view.(*worker).start(0x746ef60)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:276 +0xa0 fp=0x6c577e4 sp=0x6c57794 pc=0x141e4a0
Jan 18 16:55:38 raspberrypi grafana-server[1116]: go###.###opencensus###.io/stats/view.init.0.func1()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:34 +0x28 fp=0x6c577ec sp=0x6c577e4 pc=0x141d7f0
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c577ec sp=0x6c577ec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: created by go.###opencensus#.io/stats/view.init.0
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:34 +0x98
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 142 [select]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:363 +0x100 fp=0x6c57ef8 sp=0x6c57ee4 pc=0x5fd8c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.selectgo(0x6c57fcc, 0x6c57fc4, 0x0, 0x0, 0x2, 0x1)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/select.go:328 +0xb64 fp=0x6c57fa0 sp=0x6c57ef8 pc=0x72a1c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: database/sql.(*DB).connectionOpener(0x78b5ef0, {0x3af88f0, 0x6d8d3e0})
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/database/sql/sql.go:1224 +0x9c fp=0x6c57fdc sp=0x6c57fa0 pc=0xc29888
Jan 18 16:55:38 raspberrypi grafana-server[1116]: database/sql.OpenDB.func1()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/database/sql/sql.go:792 +0x38 fp=0x6c57fec sp=0x6c57fdc pc=0xc27b04
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c57fec sp=0x6c57fec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: created by database/sql.OpenDB
Jan 18 16:55:38 raspberrypi systemd[1]: grafana-server.service: Failed with result ‘exit-code’.
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/database/sql/sql.go:792 +0x188
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 141 [select]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:363 +0x100 fp=0x6c586f8 sp=0x6c586e4 pc=0x5fd8c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.selectgo(0x6c587d0, 0x6c587c4, 0x0, 0x0, 0x2, 0x1)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/select.go:328 +0xb64 fp=0x6c587a0 sp=0x6c586f8 pc=0x72a1c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: github.##com##/patrickmn/go-cache.(*janitor).Run(0x6c371f0, 0x6d8d320)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/opt/drone/gomodcache/github.com/patrickmn/go-cache@v2.1.0+incompatible/cache.go:1079 +0x98 fp=0x6c587e0 sp=0x6c587a0 pc=0xd494f0
Jan 18 16:55:38 raspberrypi grafana-server[1116]: github###.###com/patrickmn/go-cache.runJanitor.func1()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/opt/drone/gomodcache/github.com/patrickmn/go-cache@v2.1.0+incompatible/cache.go:1099 +0x30 fp=0x6c587ec sp=0x6c587e0 pc=0xd496c8
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c587ec sp=0x6c587ec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: created by github###.###com/patrickmn/go-cache.runJanitor
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/opt/drone/gomodcache/github.com/patrickmn/go-cache@v2.1.0+incompatible/cache.go:1099 +0x104
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 143 [select]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:363 +0x100 fp=0x6c58ed8 sp=0x6c58ec4 pc=0x5fd8c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.selectgo(0x6c58fcc, 0x6c58fb8, 0x0, 0x0, 0x2, 0x1)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/select.go:328 +0xb64 fp=0x6c58f80 sp=0x6c58ed8 pc=0x72a1c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: database/sql.(*DB).connectionCleaner(0x78b5ef0, 0xd18c2e28000)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/database/sql/sql.go:1067 +0xe8 fp=0x6c58fdc sp=0x6c58f80 pc=0xc28ca8
Jan 18 16:55:38 raspberrypi grafana-server[1116]: database/sql.(*DB).startCleanerLocked.func1()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/database/sql/sql.go:1054 +0x38 fp=0x6c58fec sp=0x6c58fdc pc=0xc28b94
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c58fec sp=0x6c58fec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: created by database/sql.(*DB).startCleanerLocked
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/database/sql/sql.go:1054 +0x204
Jan 18 16:55:38 raspberrypi systemd[1]: grafana-server.service: Consumed 10.457s CPU time.
Jan 18 16:55:38 raspberrypi systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 12.
Jan 18 16:55:38 raspberrypi systemd[1]: Stopped Grafana instance.
There seems to be a Segementation violation - I have no idea to be honest what is the probleme there ;( Maybe Someone can have a look at it and give me some hints.
Thanks a lot so far.
Hello!
The 2 Installations were carried out with:
2 (currently installed): https://dl.grafana.com/enterprise/release/grafana-enterprise_9.3.2_armhf.deb
Output of uname -a: Linux raspberrypi 5.15.84+ #1613 Thu Jan 5 11:58:09 GMT 2023 armv6l GNU/Linux
I started and enabeld the Grafana server like mentioned on the command line with the 3 commands:
sudo systemctl daemon-reload
sudo /bin/systemctl start grafana-server
sudo /bin/systemctl enable grafana-server
In the log file I tells me that i have a segmentation error.
Since I am restricted to 2 links per post please find the link to the log file bellow.
Cheers!
Logfile with error:
Okay.
Short update.
I reinstalled the ARMv6 version from:
and removed the old data with the purge command before.
Now it works.
Maybe it was the sudo apt get upgrade before the last installation that did the trick.
I have no idea.
Rasperry Pi B+ Grafana Server running.
Thanks a lot!
Thank you for updating the thread so that other people in future know what
resolved the problem for you.
Antony.
Hi @bananaluke
I getting pretty much the same issue, I have an ARMv6-compatible processor rev 7 (v6l), I had installed Grafana but it start start, now I did removed the old data with the purge command, could you tell me please what version on that list did you install ? Download Grafana | Grafana Labs and what steps did you follow? thanks in advance
