404 trying to install from debian repo
Been running grafana on Debian 11 (bullseye, raspbian), but upgrading from apt seems broken.
I re-added the apt repo since it looks like it got renamed recently from something like repository.grafana.com to apt.grafana.com. No biggie, but I still can’t upgrade because apt upgrade throws a 404.
Here’s my /etc/apt/sources.list.d/grafana:
deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main
Here’s trying to run an update:
$ sudo apt update && sudo apt upgrade
Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
Hit:2 http://deb.debian.org/debian bullseye InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:5 https://download.docker.com/linux/debian bullseye InRelease
Hit:6 https://apt.grafana.com stable InRelease
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
1 package can be upgraded. Run 'apt list --upgradable' to see it.
Calculating upgrade... Done
The following packages will be upgraded:
  grafana
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 91.3 MB of archives.
After this operation, 148 kB of additional disk space will be used.
Do you want to continue? [Y/n]
Err:1 https://apt.grafana.com stable/main arm64 grafana arm64 9.2.4
  404  Not Found [IP: 2a04:4e42:600::729 443]
E: Failed to fetch https://apt.grafana.com/pool/main/g/grafana/grafana_9.2.4_arm64.deb  404  Not Found [IP: 2a04:4e42:600::729 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Not sure what’s up, would appreciate some input. --fix-missing does not help.
Same here. I’m trying to install Grafana for my first time on RPI following this guide
but i got :
E: Failed to fetch https://packages.grafana.com/oss/deb/pool/main/g/grafana/grafana_9.2.4_armhf.deb  404  Not Found [IP: 151.101.66.217 443]
Probably a temporary error?
Someone borked the release :smiley:
lol i waited years and years for installing Grafana anche the day i decided to do it, someone bork the release… COINCIDENCE? i don’t think so…
anyway now it works
Hi @felixoghina,
Welcome to the :grafana: community support forums !!
Please follow this guide for the installation on the Debian distro:
I did?
The docs you linked to are outdated. The latest docs, which is what I followed, specify a different APT repository URL. You can see that I used this in my original post.
It seems this new repo is broken in some way. The package listing is there but the .deb files cannot be found.
Thanks @felixoghina,
for the quick reply. I see that there is currently an open issue reported by several users for the APT package manager where they have a problem in installing and updating grafana:
I suggest that you follow it up and see if this is exactly what you are also facing (if not then please open a new issue in our official GitHub repository)
I hope this helps.
Different problem that I’d already moved past, assumed it stemmed from the new repo URLs.
Anywho, the upgrade worked today, without me making any changes. I still suspect this was some sort of mishap on the repo side.
Had the same problem just now, following the updated instructions.
Failed to fetch https://apt.grafana.com/pool/main/g/grafana/grafana_9.3.0%7ebeta1_amd64.deb  404  Not Found
Commented out the beta repository in /etc/apt/sources.list.d/grafana.list and then it worked.
