Preserve Formatting for Table Visualization
In 6.x of Grafana there was an ability to choose Preserve Formatting when using a table visualization. That allowed for the dashboard to show / export with line breaks for example. I am unable to find that option in 7.x. Is there an equivalent.
Not that I know of but you can still use the old v6 table panel in v7. Either cut/paste an existing old table panel if you have one or manually change a new table panel JSON so it’s:
"type": "table-old"
While I would like to see the option ported over to the new table format, using table-old does work just fine and I can work with that. Thanks for the quick response.
