Hi guys,
Are there some way to predict traffic evolution in Grafana?
Datasource is Zabbix.
Regards!
Hi guys,
Regards!
No. But you can create calculated item in the Zabbix, which will predict metric value and then you will just visualize it in Grafana.
Recommended doc:
Another project, which can be useful for analytics of Zabbix data is (my) https://github.com/monitoringartist/monitoring-analytics - there are implemented linear/polynomial trends. You can extend a code and you can use these trends for predictions. Of course it is is standalone R web app, which you can’t integrate with Grafana.
