Possible to move/drag nodes in Node Graph Panel?
I am currently using the Node Graph Panel in Grafana.
The problem is that I want to drag all the nodes to a different location to make the node graph more readable. But it seems like I can’t drag the nodes even when in the edit screen. The documentation of this panel (Node graph | Grafana documentation) also seems to have no answer to it.
Is there any way to rearrange the nodes? Is there perhaps a plugin that could help me? And if not, can I create my own plugin to add this feature, or is that not possible?
The Grafana version is v9.5.0-cloud.5.a016665c (b2a5d45589)
Kind Regards
Yes, that works too.
Thank you!
@ngotuankiet We created a 2-part tutorial on how to display directed graphs, which can be moved, dragged, and zoomed for better visibility if you need it.
