I was wondering if there exist any plug-in (or native feature) that allows creating box-plots (boîte à moustache) from only a series of numerical values. If there is several similar series then the boxplots are shown on the same pannel.
It would be super useful for statistical visualization in the context of displaying laboratory results — hope to see that one day.
Thanks a lot in advance for your answers!
I already check this feature and I was facing a problem with time and data structure. I need the time selector to select a time period where it exists a serie of data. Then based on these numbers, the plug-in would calculate min value / 25th percentile / median value / 75th percentile / max value and realize a whisker box plot
I think you need provide more details: e.g. image what do you want exactly, source data, Grafana version, what’s a problem with candlestick, …
