Ploblem with port 443 https toolkit plugin:sign
Command:
npx @grafana/toolkit plugin:sign --rootUrls “https://example.com:443
build MANIFEST.TXT without port:
"rootUrls": [
    "https://example.com/"
When start grafana plugin.loader not find plugin:
logger=plugin.loader t=2023-02-03T15:14:04.2991495+01:00 level=warn msg="Could not find root URL that matches running application URL" plugin=json-datasource appUrl=https://example.com:443/ rootUrls=[https://example.com/]
Do you know how can I resolve?
Welcome to the :grafana: community @mp3
your problem seems similar to this one
please have a look and let us know if it helped
Yes thanks, similar with 443 port.
When I sign the plugin Grafana Server change rootUrls from https://example.com:443 to https://example.com and sign file MANIFEST.TXT.
If I configure defaults.ini with protocol=https and http_port=443 but plugin not matches, appUrl is different, if I don’t make any value in http_port Grafana use 3000 by default.
I can’t use https and 443 port with internal plugin.
I think the problem is Grafana Server that change rootUrls if we use http or https protocol with standard port, i read manifest.js and send query to sign at ‘hhttps://grafana.com/api/plugins/ci/sign’
Yes similar problem.
I did some tests the problem seems to be in the “SIGN” phase the manifest.js program sends the signature request to this server: “https://grafana.com/api/plugins/ci/sign” which modifies the rootUrls by removing 443, in the start phase of grafana.exe the internal plugin does not start because appUrl is different to rootUrls in MANIFEST.TXT. I tried removing the http_port from the defauls.ini file but in this case the plugin loads but the programme starts with port 3000 by default.
As a result it is not possible to use Grafana in https with the standard port 443 and a private plugin.
Hello @mp3,
since 443 is the default https port (same as :80 is the default http port), could you just try not providing it?
e.g. use npx @grafana/toolkit plugin:sign --rootUrls https://your-domain.com/ instead of npx @grafana/toolkit plugin:sign --rootUrls https://your-domain.com:443/
Thanks, but if I use
and write nothing value in defaults.ini:
http_port =
grafana start with 3000 by default, if I write 443 in defaults.ini at start of plugin appUrl is :
https://your-domain.com:443/ and rootUrls is https://your-domain.com/ and not matches.
I think the problem is only I use the private plugin, I write plugin to connect, in SQL sintax, to a non stardard DB (advantage database)
Massimo
Please configure root_url to your public facing URL, e.g. https://your-domain.com.
Working, perfect and simple.
From
root_url = %(protocol)s://%(domain)s:%(http_port)s/
to
root_url = https://exmple.com
Thanks
Massimo
