Can I sign a private plugin without knowing exact rootUrl
I developed a plugin which I want to share with a few person. Since this plugin is used between a few users, I don’t plan to publish it to plugin category. So, I am trying to sign a private plugin, but I can’t assume what’s the exact root_url of the grafana instance where this plugin will be installed. I tried wildcards, such as “.com", ".**”, signing command succeeded, but grafana couldn’t load my plugin
What can I do to sign my plugin?
Maybe allowing this plugin to be loaded unsigned in grafana.ini would be suitable in your case?
[plugins]
allow_loading_unsigned_plugins = fyzjw123-private-plugin
Thanks @ebabeshko for your reply, this maybe not suitable, users are prefer to disable allow_loading_unsigned_plugins.
Hi @fyzjw123
You can find all information about signing private plugins in our documentation Sign a plugin | Grafana Plugin Tools
To reply to your question, no, you must specify the rootUrl when you sign a private plugin. If you wish your plugin to work in all instances without specifying it you’ll have to go through the review process to publish your plugin in the Grafana catalog or allow grafana to load an unsigned plugin.
OK, got it. Thanks @academo
i actually have the opposite problem when running Grafana using docker compose. I can sign my plugin only to be used with localhost:3000, otherwise grafana won’t register it upon load.
This way i can’t restrict my plugin to be used only on certain domains
Share the command you are using to sign your plugin. It might be you are putting the wrong parameters.
npx @grafana/sign-plugin@latest --rootUrls https://mapgl.org
Grafana docker container logs:
logger=plugin.signature t=2024-08-28T13:32:36.75597604Z level=warn msg="Could not find root URL that matches running application URL" plugin=vaduga-mapgl-app appUrl=http://localhost:3000/ rootUrls=[https://mapgl.org/]
logger=plugin.loader t=2024-08-28T13:32:36.879017826Z level=warn msg="Skipping loading plugin due to problem with signature"
so,
npx @grafana/sign-plugin@latest --rootUrls http://localhost:3000
works, but then the plugin can be used on any domain. How do I make it restricted to certain domains, and still use docker compose?
@vaduga are you running grafana behind a reverse proxy? are you correctly setting the domain in the configuration file?
thanks a lot! Specifying the same domain in dockerfile as in manifest file was enough to register the signed plugin
ENV GF_SERVER_DOMAIN "mapgl.org"
I’m having the same problem where I have the plugin signed at a private URL like my.grafana.com and I want to test the signed plugin locally but get something like:
Could not find root URL that matches running application URL" plugin=my-datasource appUrl=http://localhost:3000/ rootUrls=["https://my.grafana.com"]
I also don’t want to sign the plugin with localhost as a rootURL. I tried setting the environment variable when building my custom Grafana image with ENV GF_SERVER_DOMAIN “my.grafana.com” but that results in the same error. I’m building the Grafana image off of version 12.4.1.
