I want to solve the problem.
my grafana config
[server]
protocol = https
http_port = 3000
root_url = %(protocol)s://%(domain)s:%(http_port)s/grafana/
serve_from_sub_path = true
nginx config
server {
listen 443 ssl;
server_name _;
ssl_certificate cert.pem;
ssl_certificate_key rsa.key;
client_max_body_size 500M;
location /grafana/ {
proxy_pass https://localhost:3000/;
private plugin error
t=2021-12-23T08:36:20+0000 lvl=warn msg=“Could not find root URL that matches running application URL” logger=plugins plugin=loveiskin-my-datasource appUrl=https://localhost:3000/grafana/ rootUrls="[https://localhost:3000/grafana/]"
t=2021-12-23T08:36:21+0000 lvl=warn msg=“Some plugin scanning errors were found” logger=plugins errors=“plugin ‘loveiskin-my-datasource’ has an invalid signature”
Note the following:
