ok, thanks for the update. I hadn’t managed to find that list on github.
Now that you have posted the link my curiosity has been peaked. The request to have public playlist playable is under ‘Spike’ - which would imply its just an experiment. The kiosk link under both dashboards and playlists seems like a feature of Grafana rather than something experimental.
On the basis that the option is there on both dashboards and playlists without any note attached indicating only-works-in-some-cases, then it should work. Non-working public playlists should count as a bug rather than an enhancement… but given it appears under Spike, is there a chance this funcionality is just experimental code and may be removed again?
dashboards and public dashboards are two independent areas
The spike is meant for studying the feasibility of implementing a dashboard-original solution in public dashboards. There are no plans to discontinue public playlists.
