Grafana 9.1.6 running in the official docker image grafana/grafana:9.1.6 -
I have built a pie chart from a metric. Everything is fine with the exception that the literal query is displayed as another value in the legend. -
The query is:sum by (key1) (increase(my_metric)[10y]) -
What happened?
This query is shown as part of the legend. -
Legend only shows the sum by keys.
This happens when there is an empty value in the label. For instance, let’s say you have a metric my_metric{l1="", l2="test2"}. Then l1="" will be displayed as the query because there is no value.
Even thought this can be prevented, I don’t think this is the correct way to handle it.
