Pie Chart in Grafana 7.3.1
  • What Grafana version and what operating system are you using? 7.3.1 on Linux x86-64 4.14.35-1818.3.3.el7uek.x86_64
  • What are you trying to achieve? I need to build a pie graph pulling information from an Oracle database enterprise manager repository that shows database instances grouping by status; the pie will split and represents percentage values for:
    • green for instances up & running
    • red for instances down or unreachable
    • light blue for instances under blackout
    I have tried to create this with the target metric, but I am getting no values and it would only show it for one database. I have tried to create a custom query in several different ways, but the pie chart is always empty.
pie chart > Time Series > Custom Repository
  • What happened? The pie chart remains empty
    Well, I hoped it would show a problem with the sql or show a pie chart that I didn’t want or a pie chart that I did want. Any thing that would help me test this out and set up correctly.
    No error, just no data. When the same sql is run from sqlplus, I get output.
  • Did you follow any online instructions? If so, what is the URL? I reviewed the pie chart docs on grafana.
The sql attempted:
SELECT “COLLECTION_TIMESTAMP” as time_sec, data_value as status, metric_nam e as metric FROM “SYSMAN”.“EM$CURRENT_METRICS” where metric_name=‘Response’ AND target_type=‘oracle_database’ order by COLLECTION_TIMESTAMP ASC;
select start_timestamp as time_sec, availability_status_code as value, targ et_name as metric
from mgmt$availability_current
where target_type=‘oracle_database’
order by start_timestamp ASC;
SELECT c.start_timestamp as time_sec, c.availability_status_code AS Status
FROM mgmt$availability_current c, sysman.gc_manageable_entities t
WHERE t.entity_type = ‘oracle_database’
AND c.target_guid = t.entity_guid
ORDER BY c.start_timestamp ASC;
Any help is appreciated. Thanks.
Hi @jennifergramling
Thanks for this very thorough topic thread and welcome to the forum!
Ok, so my first suggestion would be to upgrade to Grafana 8, which shipped with a brand new core pie chart visualization. It is much improved. You can check it out here:
https://play.grafana.org/d/ktMs4D6Mk/5-bar-charts-and-pie-charts?orgId=1
