I am using pie chart plugin to see data from splunk, when i click on the value, the value is not sorted and the graph colour is not changing according to that. is this the normal behaviour of pie chart ?
Don’t understand. What do you mean by “click on the value”? Seems to work for me (if this is what you mean):
Nope. By click on values (on top right hand side), does it sort and colour change accordingly ?
When you click on the “values” field , does your value got sorted and the colour changes?
For example, in histogram when you click on the values filed, the values are sorted . lets say highest value will display first and corresponding chart for the value will display first.
