Panels in rows and cpu usage
I would like to ask if packing panels into rows in dashboard help to reduce cpu usage.
Thanks for repplies
Heyy there!
In general, placing panels inside rows does not directly reduce CPU usage. In Grafana, CPU load mainly depends on how many queries are executed, how complex those queries are, and how often the dashboard refreshes.
Rows are mostly a visual grouping feature. However, if rows are collapsed, some data sources may delay rendering until the row is expanded, which can slightly reduce browser-side load.
If you want to lower CPU usage, it is usually more effective to reduce refresh frequency, simplify queries, or use query caching rather than reorganizing panels into rows.
No — putting panels inside rows does NOT reduce CPU usage.
In Grafana:
A row is just a visual grouping element.
It does not change how queries execute.
CPU usage mainly depends on:
1.Number of panels
2.Query complexity
3.Refresh interval
4.Data source performance
5.Transformations inside panels
So:
10 panels in rows = 10 panels without rows
CPU impact is the same.
