My Y-axis in the panel are in byte/sec, but when the dashboard is exported, the receiving system gets “decBps”. We thought it would be the minor version difference, but on my exporting system I also see it when I view the JSON definition.
“yaxes”: [
“format”: “decBps”,
“label”: null,
“logBase”: 1,
“max”: null,
“min”: null,
“show”: true
My colleague tells me it fails when importing the dashboard created on 7.2.0 in a 7.1.5 level
Hello @rvdheij, this is probably connected to this change. Just now, there was created a similar/related issue on github. I am going to link there this thread, but it would be great if you mentioned your issue there as well.
Sure, I had held back creating an issue until I understand where the issue actually is. I just checked that an 7.1.3 system has "format" : "Bps" and my 7.2.0 has "format" : "decBps" That makes it feel like a new bug, rather than an old one that is gone.
