Panel x axis labels time format
    Grafana v10.2.0
    Time format for the x axis labels
    Defined Time override
  • What happened?
    For tooltips it works, for the x axis labels no change
    time format for the x axis labels as configured with the override
  "datasource": {
    "type": "tribe-29-checkmk-datasource",
    "uid": "b46ddbd4-a196-40b7-8c51-12aac6012194"
  "description": "",
  "fieldConfig": {
    "defaults": {
      "custom": {
        "drawStyle": "line",
        "lineInterpolation": "smooth",
        "barAlignment": -1,
        "lineWidth": 3,
        "fillOpacity": 100,
        "gradientMode": "scheme",
        "spanNulls": false,
        "insertNulls": false,
        "showPoints": "auto",
        "pointSize": 4,
        "stacking": {
          "mode": "none",
          "group": "A"
        "axisPlacement": "auto",
        "axisLabel": "",
        "axisColorMode": "text",
        "axisBorderShow": false,
        "scaleDistribution": {
          "type": "linear"
        "axisCenteredZero": false,
        "hideFrom": {
          "tooltip": false,
          "viz": false,
          "legend": false
        "thresholdsStyle": {
          "mode": "off"
        "axisSoftMin": 0,
        "lineStyle": {
          "fill": "solid"
      "color": {
        "mode": "thresholds",
        "fixedColor": "light-green",
        "seriesBy": "last"
      "mappings": [],
      "thresholds": {
        "mode": "absolute",
        "steps": [
            "color": "#224488",
            "value": null
            "color": "#660000",
            "value": 47.6
      "displayName": "Temperature Outside",
      "unit": "celsius"
    "overrides": [
        "matcher": {
          "id": "byName",
          "options": "Temperature"
        "properties": [
            "id": "color",
            "value": {
              "fixedColor": "green",
              "seriesBy": "last"
        "matcher": {
          "id": "byName",
          "options": "Time"
        "properties": [
            "id": "unit",
            "value": "dateTimeAsIsoNoDateIfToday"
  "gridPos": {
    "h": 9,
    "w": 12,
    "x": 0,
    "y": 0
  "hideTimeOverride": true,
  "id": 8,
  "options": {
    "tooltip": {
      "mode": "single",
      "sort": "none"
    "legend": {
      "showLegend": true,
      "displayMode": "table",
      "placement": "bottom",
      "calcs": [
        "min",
        "mean",
        "max",
        "lastNotNull"
  "targets": [
      "datasource": {
      "refId": "A",
      "requestSpec": {
        "aggregation": "off",
        "graph": "METRIC_Temperature",
        "graph_type": "predefined_graph",
        "host_name": "KENIG",
        "service": "Temperature Outside",
        "site": "monitoring"
  "timeFrom": "now-14d",
  "transformations": [],
  "type": "timeseries"
Please advise.
UPDATE
The date and time formats are taken from the grafana.ini file (Linux), however, it is not enough to reload the dashboard, you need to reload the page in the browser (after restarting the Grafana server).
This is addressed in v12.3 where you can do straight from an override.
