There’s a “tutorial” about making a topics…inside yours!
What’s your Grafana version? Are you using stats panel, or another one?
If your issue is about centering your title I recommend you to red this topic.
I couldn’t find a way to do that in an “easy” way.
It’s kinda weird that there’s no native solution to chose the placement of the content of panels…
Maybe you can look if a feature request exist on the GitHub?
Well actually I found out that it might (might isn’t “it’s possible”) be possible using the text panel with HTML and CSS code. But this is a workaround and I’ll not be able to help you on modifying the content of the panel using that… You should take a look at the solution provided by @jangaraj.
Yeah you probably can modify the code of your panel if you are using your own Grafana instance and you are admin. I don’t know how and I really don’t think that’s a good idea… Open-source doesn’t mean “I can do whatever I want with the code and it’ll work”.
