Hello Grafana community,
I’m using Grafana version 10.0.3 and I’m looking for a way to center-align the title of a panel within a dashboard. Unfortunately, I cannot find a straightforward option or setting to achieve this.
In my Grafana version, the custom CSS option is not available for panels. As a result, the usual approach of using custom CSS to center the title is not applicable.
If anyone has experience with Grafana version 10.0.3 and has found a workaround or solution to centrally align the title of a panel, I would greatly appreciate your insights and guidance. I’m open to suggestions.
Thank you in advance for your help!
