I am using stat plugin and my grafana version is 11.1.0 ,
I want panel and value coming inside panel in left alignment like is addressed in above image
There are only two option available for stat plugin auto and center
Can you please give me solution
And solution is not possible Then can i modify code in grafana I will able to acccess files
