10.3 and 10.4 -
after update 10.01 to 10.4 -
What happened?
dashboard with “stat” plugin work fine in 10.0 but not in 10.3 and more -
**plugin “stat” with “dashboard” as datasource show value (function “count”) even if panel doesn’t appear (panel is at the end of dashboard) but with 10.3/10.4 version ,the value appears only after if i go to watch the panel at the end of dashboard and came back **
i tried to create a new panel with “stat” but i have the same problem
