Hello everybody,
I hope you can help me.I have the following problem:
Some panels are not loaded via the Auth Proxy.
The error e.g. “Panel plugin not found: grafana-clock-panel is coming.”
When calling via the normal port, everything works as usual.
Here is my configuration:
grafana.ini:
[server]
protocol = https
domain = domain.de
rout_url = https://domain(.)de
[auth.proxy]
enabled = true
header_name = X-WEBAUTH-USER
header_property = username
auto_sign_up = true
cert_file = /ssl/domain(.)de.crt
cert_key = /ssl/domain(.)de.key
Apache Conf:
<VirtualHost *:8090>
ServerAdmin webmaster@authproxy
ServerName domain(.)de
ServerAlias domain(.)de
ErrorLog “/MySystem/logs/grafana-authproxy-error_log”
CustomLog “/MySystem/logs/grafana-authproxy-access_log” common
SSLEngine on
SSLCertificateKeyFile /ssl/domain(.)de.key
SSLCertificateFile /ssl/domain(.)de.crt
<Proxy *>
AuthType Basic
AuthName GrafanaAuthProxy
AuthBasicProvider file
AuthUserFile /etc/apache2/grafana_htpasswd
Require valid-user
RewriteEngine On
RewriteRule .* - [E=PROXY_USER:%{LA-U:REMOTE_USER},NS]
RequestHeader set X-WEBAUTH-USER "%{PROXY_USER}e"
</Proxy>
RequestHeader unset Authorization
SSLProxyEngine on
ProxyRequests Off
ProxyPass / https://domain.de:3000/
ProxyPassReverse / https://domain.de:3000/
</VirtualHost>
These (.) are of course normal “.”.
I hope you have a good suggestion what this can be.Thanks for your time
